[Resolved] Ethernet shield
Hi all,
I've done a lot of searching but I haven't found a clear answer. I have an Ethernet shield - I believe its a rev2, it says "mega compatible" on it. :slight_smile:
This looks like mine: http://arduino.cc/en/uploads/Guide/ArduinoWithEthernetShield.jpg
Will this work without issue on the Due?
thanks in advance,
Dan
It wouldn't work correctly due to the lack of an IOREF pin on the REV2 Ethernet shield, which means if you used that one you would be risking destroying the due
Thanks for the clarification tmbates :slight_smile:
