Hi all,
I’m working on a cosplay prop that utilizes neopixels as well as traditional LEDs to create a few different effects. The illumination modes are changed via a button press that controls a switch-case as follows:
(currently using a single LED as an indicator for the case being switched, waiting for parts to come end of the week)
case 0 - LED off
case 1 - LED blinks
case 2 - Full, continuous illumination
case 3 - 50% illumination (allows for bluetooth control of neopixel)
another button press resets the case to 0 and we loop around.
I initially just had the four cases without BLE added, changing the LED’s behavior and it worked fine. Now that I’ve added the neopixel and BLE code I’m 50-50 either not getting a response to the button at all OR when I reach case 3 the case does not change again on button press and I get stuck at case 3. I’m clearly not seeing whatever is going wrong and could use some extra eyes. Code below. Thanks in advance
#include <string.h>
#include <Arduino.h>
#include <SPI.h>
#include <Adafruit_ATParser.h>
#include <Adafruit_BLE.h>
#include <Adafruit_BluefruitLE_SPI.h>
#include <Adafruit_BluefruitLE_UART.h>
#if SOFTWARE_SERIAL_AVAILABLE
#include <SoftwareSerial.h>
#endif
#include "BluefruitConfig.h"
//neopixel and BLE definitions
#define FACTORYRESET_ENABLE 0
#define PIN 9
#define NUMPIXELS 1
//create neopixel and bluefruit objects
Adafruit_NeoPixel pixel = Adafruit_NeoPixel(NUMPIXELS, PIN);
Adafruit_BluefruitLE_SPI ble(BLUEFRUIT_SPI_CS, BLUEFRUIT_SPI_IRQ, BLUEFRUIT_SPI_RST);
//LED status pin variables
const byte ledPin = 5;
int ledState = 0;
//button pin variables
const byte buttonPin = 6;
int buttonState;
int reading;
int lastButtonState = LOW;
//switch mode variables
int mode = 0; //selector state
//debounce check variables
unsigned long lastDebounceTime = 0; // the last time the output pin was toggled
unsigned long debounceDelay = 50; // the debounce time; increase if the output flickers
//variables for blinking function
const long blinkInterval = 1000; //blink without delay interval for case 1
unsigned long currentMillis=0;
unsigned long blinkingMillis=0;
// A small helper
void error(const __FlashStringHelper*err) {
Serial.println(err);
while (1);
// function prototypes over in packetparser.cpp
uint8_t readPacket(Adafruit_BLE *ble, uint16_t timeout);
float parsefloat(uint8_t *buffer);
void printHex(const uint8_t * data, const uint32_t numBytes);
// the packet buffer
extern uint8_t packetbuffer[];
pinMode(buttonPin,INPUT);
pinMode(ledPin,OUTPUT);
//set initial LED state
analogWrite(ledPin, ledState);
//neopixel and BLE initialization
while (!Serial); // required for Flora & Micro
// turn off neopixel
pixel.begin(); // This initializes the NeoPixel library.
for(uint8_t i=0; i<NUMPIXELS; i++) {
pixel.setPixelColor(i, pixel.Color(0,0,0)); // off
pixel.show();
Serial.println(F("Adafruit Bluefruit Neopixel Color Picker Example"));
Serial.println(F("------------------------------------------------"));
/* Initialise the module */
Serial.print(F("Initialising the Bluefruit LE module: "));
if ( !ble.begin(VERBOSE_MODE) )
error(F("Couldn't find Bluefruit, make sure it's in CoMmanD mode & check wiring?"));
Serial.println( F("OK!") );
if ( FACTORYRESET_ENABLE )
/* Perform a factory reset to make sure everything is in a known state */
Serial.println(F("Performing a factory reset: "));
if ( ! ble.factoryReset() ){
error(F("Couldn't factory reset"));
/* Disable command echo from Bluefruit */
ble.echo(false);
Serial.println("Requesting Bluefruit info:");
/* Print Bluefruit information */
ble.info();
Serial.println(F("Please use Adafruit Bluefruit LE app to connect in Controller mode"));
Serial.println(F("Then activate/use the sensors, color picker, game controller, etc!"));
ble.verbose(false); // debug info is a little annoying after this point!
/* Wait for connection */
while (! ble.isConnected()) {
Serial.println(F("***********************"));
// Set Bluefruit to DATA mode
Serial.println( F("Switching to DATA mode!") );
ble.setMode(BLUEFRUIT_MODE_DATA);
int reading = digitalRead(buttonPin);
if (reading != lastButtonState){
//reset the debouncing timer
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
//debounce check
if (reading != buttonState){
buttonState = reading;//update buttonState
if (buttonState == HIGH){
mode++;//cycle the case on button press
if (mode <= 3){
switch (mode) {
case 0:
//case 0 is everything shut off
ledState = 0;
case 1:
pixelBlinking();
case 2:
// case 2 is led solid
ledState = 255;
case 3:
//case 3 enables neopixel color picking via BLE app
//it currently sets the led at half brightness to show activity
ledState = 127;
pixelColorPicker();
else {
mode = 0;
lastButtonState = reading;
void pixelColorPicker(){
/* Wait for new data to arrive */
uint8_t len = readPacket(&ble, BLE_READPACKET_TIMEOUT);
if (len == 0) return;
/* Got a packet! */
// printHex(packetbuffer, len);
// Color
if (packetbuffer[1] == 'C') {
uint8_t red = packetbuffer[2];
uint8_t green = packetbuffer[3];
uint8_t blue = packetbuffer[4];
Serial.print ("RGB #");
if (red < 0x10) Serial.print("0");
Serial.print(red, HEX);
if (green < 0x10) Serial.print("0");
Serial.print(green, HEX);
if (blue < 0x10) Serial.print("0");
Serial.println(blue, HEX);
pixel.setPixelColor(i, pixel.Color(red,green,blue));
pixel.show(); // This sends the updated pixel color to the hardware.
void pixelBlinking(){
currentMillis = millis();
if (currentMillis - blinkingMillis >= blinkInterval) {
// save the last time you blinked the LED
blinkingMillis = currentMillis;
// if the LED is off turn it on and vice-versa:
if (ledState == 0) {
ledState = 255;
ledState = 0;
// set the LED with the ledState of the variable:
