The transmitting burst will cause voltage drop and the power supply must be able to provide sufficient current up to 2A. The USB port can not supply such a large current.
The w5100 uses quite a bit of power also (> 130ma). Used by themselves, there may be just enough power, but the combination may be too much for the power supply.
do you think that I have supply my GSM module too?
Yes.
Posting your code might be a good idea, too. That would let us see if there is a pin conflict. For instance, if you are using pins 10 and 11 for a SoftwareSerial interface, which is not uncommon, that WILL interfere with the ethernet shield, and vice versa. Though it looks like that shield offers a choice of the hardware serial port (pins 0 and 1) or pins 2 and 3.
// Erick Eden Fróes
// www.wenomine.com
#include <SoftwareSerial.h>
#include <SPI.h>
#include <Ethernet.h>
//50 rx e 51 tx
SoftwareSerial mySerial = SoftwareSerial(51,50);
char flag=0;
//Configurações do Ethernet Shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,0,177);
int led = 23;
const int sensor_pir = 22;
boolean alarme = false;
int meuNumero = 998016219;
// String que representa o estado dos dispositivos
char Luz[7] = "0000L#";
EthernetServer server(80); // Cria o servidor na porta 8081
// String onde é guardada as msgs recebidas
char msg[7] = "0000L#";
pinMode(23,OUTPUT);
//pinMode(9,OUTPUT);
pinMode(sensor_pir, INPUT);
mySerial.begin(19200);
Ethernet.begin(mac, ip);
server.begin();
//Serial.print("server is at ");
//Serial.println(Ethernet.localIP());
mandaSMS();
// SE receber um caracter...
int estado_sensor = digitalRead(sensor_pir);
if(alarme == true){
if (estado_sensor == HIGH) {
Serial.println("Intruso");
client.write("Intruso");
//digitalWrite(9,HIGH);
mandaSMS();
//ligar();
//alarme = false;
if (client) {
// guarda o caracter na string 'msg'
msg[1]=msg[2]; msg[2]=msg[3]; msg[3]=msg[4]; msg[4]=msg[5]; msg[5]=msg[6];
msg[6] = client.read();
//if HTTP request has ended
if (msg[6]=='#') {
switch(msg[5]) {
case 'R':
// Se receber o comando 'R#' envia de volta o status dos
// dispositivos. (Que é a string 'Luz')
client.write(Luz);
case 'P':
// Caso P#, aciona o pino do portão pequeno por 1s.
digitalWrite(A4,HIGH);
digitalWrite(A4,LOW);
case 'G':
// Caso G#, aciona o pino do portão pequeno por 1s.
digitalWrite(A5,HIGH);
digitalWrite(A5,LOW);
case 'L':
// Caso L#, ele copia os 4 bytes anteriores p/ a
// string 'Luz' e cada byte representa um
// dispositivo, onde '1'=ON e '0'=OFF
Luz[0]=msg[1];
Luz[1]=msg[2];
Luz[2]=msg[3];
Luz[3]=msg[4];
Serial.print(Luz[0]);
if (Luz[0]=='1') {
digitalWrite(23,HIGH);
alarme= true;
}else{
digitalWrite(23,LOW);
//digitalWrite(9,LOW);
alarme= false;
if (Luz[1]=='1') digitalWrite(1,HIGH); else digitalWrite(1,LOW);
if (Luz[2]=='1') digitalWrite(2,HIGH); else digitalWrite(2,LOW);
if (Luz[3]=='1') digitalWrite(3,HIGH); else digitalWrite(3,LOW);
void mandaSMS(){
if(flag==0)
mySerial.print("AT+CMGF=1\r"); //mandando SMS em modo texto
mySerial.print("AT+CMGS=\"+99801****\"\r"); // numero que vamos mandar o SMS
Serial.println("SMS Armado");
flag=1;
if(flag==1)
mySerial.print("Perimetro invadido!Alarme disparado!\r"); // corpo da msg
mySerial.write(0x1A); //equivalente a mandar Ctrl+Z(finaliza corpo do SMS)
Serial.println("Pronto pra enviar");
flag=2;
if(flag==2)
Serial.println("SMS Enviado com sucesso!");
delay(5000);
flag=3;
void ligar(){
mySerial.println("\r");
mySerial.println("AT+CMGF=1\r");
if (mySerial.available())
mySerial.println("ATD 99801****;"); // numero a ser discado
delay(10000); //completar licação
delay(6000); //receber licação, esperar.
mySerial.println("ATH0"); //finaliza ligação
I'm try using hardware serial ports, but it's fail...
I do it
// Erick Eden Fróes
// www.wenomine.com
//#include <SoftwareSerial.h>
#include <SPI.h>
//50 rx e 51 tx
//SoftwareSerial mySerial = SoftwareSerial(51,50);
char flag=0;
int led = 23;
pinMode(23,OUTPUT);
Serial2.begin(19200);
server.begin();
mandaSMS();
if(alarme == true){
mandaSMS();
//ligar();
//alarme = false;
if (client) {
if (msg[6]=='#') {
switch(msg[5]) {
case 'R':
client.write(Luz);
case 'P':
case 'G':
case 'L':
Luz[0]=msg[1];
Luz[1]=msg[2];
Luz[2]=msg[3];
Luz[3]=msg[4];
if (Luz[0]=='1') {
alarme= true;
}else{
alarme= false;
void mandaSMS(){
if(flag==0)
Serial2.print("AT+CMGF=1\r"); //mandando SMS em modo texto
Serial2.print("AT+CMGS=\"+99801****\"\r"); // numero que vamos mandar o SMS
flag=1;
if(flag==1)
Serial2.print("Perimetro invadido!Alarme disparado!\r"); // corpo da msg
Serial2.write(0x1A); //equivalente a mandar Ctrl+Z(finaliza corpo do SMS)
flag=2;
if(flag==2)
delay(5000);
flag=3;
void ligar(){
I am surprised it works on pins 40 and 41. The SoftwareSerial rx pin needs to be a change interrupt capable pin, and neither of those are. Check here under "Limitations".
edit: If you are never receiving anything from the GSM module, it will work ok. It appears you never receive anything from it with your code.
