Hello Learned Gentlemen
May I get some help on why something like the below won't work and perhaps how to accomplish it the correct way?
When compliling I get the following error:
assignment of read-only location 'analogueRead*'*
*const int var[] = {0,1,2,3,4,5,6,7};
void loop () {
for(i = 0; i < 8; i++); {
var[i] = analogRead(i);
* *In composing this topic I actually figured out the error!* *var is set as a const!* *
*int var[] = {0,1,2,3,4,5,6,7};
void loop () {
Fixed!
TheDanger:
void loop () {
Fixed!
Nope.
It only compiles now, it will not work as expected...
Hint: imagine the second time loop is executed, which analog ports will be used?
I was misleaded by the superfluous initialization.
What code will be executed for each step of the for loop ?
I stripped back the code to the part causing the issue. Thus it looks like it doesn't do much
int var[8];
Is that better Whandall?
I would prefer it.
A definition of the variable i would help also.
next time I'll post the code as is! I actually renamed it for simplicity in the forum. You can probably guess why
for (int in = 0; in < 8; in++) {
analogueRead[in] = analogRead(in); // <-------This line here!
batV[in] = (analogueRead[in] * powerV) / 1024;
Serial.print(" A"), Serial.print((in + 1)), Serial.print(":"), Serial.print(analogueRead[in]);
Serial.print(" B"), Serial.print((in + 1)), Serial.print(":"), Serial.print(batV[in]);
int val = map(analogueRead[in], 0, 1023, 0, 255);
if (batV[in] >= 4.00) {
strip.setPixelColor(in, 0, val, 0);
// strip.show();
if (batV[in] >= 3.00 && batV[in] <= 4.00) {
strip.setPixelColor(in, 0, 0, val);
// strip.show();
if (batV[in] < 3.00) {
strip.setPixelColor(in, val, 0, 0);
// strip.show();
strip.show();
if (in == 7) {
Your code could be neater and avoid multiple tests for values if it were something like this (untested)
byte r = 0;
byte g = 0;
byte b = 0;
g = val;
else if (batV[in] >= 3.00)
b = val;
r = val;
strip.setPixelColor(in, r, g, b);
