i am playing around with the ATtiny85 and there's plenty resources out there to guide one along.
(it was such a breeze - so much easier than an Arduino Standalone on a breadboard even !!)
anyway, so i have uploaded a Blink sketch to the ATtiny85 using ArduinoISP and ICSP connections - it's really so simple - i don't know why people want an even easier way with the TX/RX method using SoftwareSerial ... (n00b getting ahead of himself !!).
problem being, the timing is off - i used the internal crystal and have since read on the definitive thread (of using the ATtiny85)
Arduino Tiny - Microcontrollers - Arduino Forum (Page 3) that it's recommended to use an external crystal - no problem, i will comply duly.
EDIT:
wrong thread linked above - that is infact for the Arduino Tiny CODE.
this one here is for the ATtiny CHIP; (Page 3)
and here's the comment on problems with external crystals;
thing is, i'm using IDE 1.0.5 and that meant i downloaded the "old" version (from github = attiny-ide-1.0.x.zip
) which uses boards.txt instead of the latest one kept at GoogleCode ( =arduino-tiny-0100-0018.zip
that means, the "Boards" available in the IDE are only (internal 1 MHz), (internal 8 MHz) and (external 20 MHz).
i have downloaded both 'masters' though - and saw that there is a "Prospective Boards.txt" file in the newer one.
so; i figure i should just EDIT the boards.txt and add my own entry following the "code" in that "Prospective Boards.txt" file for external 16 MHz
attiny85at16e.name=ATtiny85 @ 16 MHz (external crystal; 4.3 V BOD)
# The following do NOT work...
# attiny85at16e.upload.using=avrispv2
# attiny85at16e.upload.using=Pololu USB AVR Programmer
# The following DO work (pick one)...
attiny85at16e.upload.using=arduino:arduinoisp
# attiny85at16e.upload.protocol=avrispv2
# attiny85at16e.upload.using=pololu
attiny85at16e.upload.maximum_size=8192
# Ext. Crystal Osc.; Frequency 8.0- MHz; Start-up time PWRDWN/RESET: 16K CK/14 CK + 65 ms; [CKSEL=1111 SUT=11]
# Brown-out detection level at VCC=4.3 V; [BODLEVEL=100]
# Preserve EEPROM memory through the Chip Erase cycle; [EESAVE=0]
# Serial program downloading (SPI) enabled; [SPIEN=0]
attiny85at16e.bootloader.low_fuses=0xFF
attiny85at16e.bootloader.high_fuses=0xD4
attiny85at16e.bootloader.extended_fuses=0xFF
attiny85at16e.bootloader.path=empty
attiny85at16e.bootloader.file=empty85at16.hex
attiny85at16e.build.mcu=attiny85
attiny85at16e.build.f_cpu=16000000L
attiny85at16e.build.core=tiny
am i on the right track ?
i just wanted confirmation that this is the right way to do it and i don't end up burning wrong fuses and bricking the chip.
Thanks !
P.S
just glancing through that; i noticed - attiny85at16e.upload.maximum_size=8192
i think i've also read there are bugs when using the older IDE regarding sketches above 4KB - should i drop that '8192' to '4096' ?
