UPDATE:
I have partially found a solution. And I now know how to fix the problem, I just need to know what to write. If I add a delay, say 500 milliseconds, it works OK as long as the user inputs the data before that delay is over. It works, but I don't like that, I don't want delays, it needs to work with the user. As in wait for them to input the full string and then move on.
Updated Code Piece: This is the command 'pinConfig', the problem is the lack of wait time
if (commandIn == "pinConfig") //the user wants to configure a pin
Serial.println("CHOOSE A PIN [2-13]"); //Pins 0-1 are not for user use
lcd.clear();
lcd.print("CHOOSE PIN: 2-13"); //show some info on the LCD
String serialPin;
Serial.flush();
delay(500); //this delay sort of fixes the problem but I don't like it
serialPin = Serial.readString(); //serialPin reads the raw input
Serial.flush();
static int pinNumberSerial = serialPin.toInt(); //pinNumberSerial gets the integer version of the input
Serial.print("'");
Serial.print(serialPin); //The pin number should show up on serial, but it is always zero
Serial.println("'"); //the quotes are so I can tell if there is nothing there
Hello Community! I have a circuit takes in commands from the serial monitor, and can configure individual pins 2-13 from serial. All of the other commands work, except the 'configure pin' command; it should be the way described below:
How it Should Work:
- User types in "pinConfig".
SCREEN: "CHOOSE A PIN [2-13]" - User types in a pin number (lets say 5).
SCREEN: "PIN 5 CONFIGURE"
SCREEN: "INPUT OR OUTPUT [1/2]" - User types in a setting (lets say 1).
SCREEN: "PIN 5 NOW INPUT" - User is happy and gets ice cream.
How it Really Works:
SCREEN: "CHOOSE A PIN [2-13]" - User types in a pin number (lets say 3)
SCREEN: nothing - User Resets and tries Everything Again.
SCREEN: nothing - User checks code and researches, then tries again
SCREEN: nothing - User gives up and goes to forum
As you can see, this code has a problem with accepting pin numbers after text, I think. I know that it can get to the command, but it wont do anything after the command is started. I've tried multiple attempts, but I cant get any further. Any help is appreciated. Thanks!
The Code:
//Created: April 3, 2016 by mike44449
#include <LiquidCrystal.h>
LiquidCrystal lcd(44, 45, 32, 34, 36, 38); //Pins for Mega 2560
String SerialCommand, commandIn;
int pinNumber = 0;
int pinState;
int pinConfig;
int pinRead;
const int backlight = 53; //Connect the base of the transistor to 53
pinMode(backlight, OUTPUT);
digitalWrite(backlight, HIGH); // turn on the backlight
pinMode(13, OUTPUT);
digitalWrite(13, LOW); //turn off the onboard LED
Serial.println("Welcome to the Digital Workstation! v1.5"); //Display some commands and information
Serial.println("\nCOMMANDS:");
Serial.println("pinConfig - SPECIFY A PIN"); //choose a pin to modify
Serial.println("allON - ALL PINS HIGH"); //all pins on
Serial.println("allOFF - ALL PINS LOW"); //all pins off
Serial.println("allIN - ALL PINS INPUT"); //all pins are inputs
Serial.println("allOUT - ALL PINS OUTPUT"); //all pins are output
Serial.println("readAll - READ ALL PINS"); //display a summary of pin readings
Serial.println("backlightON - TURN ON BACKLIGHT"); //turn on the backlight
Serial.println("backlightOFF - TURN OFF BACKLIGHT"); //turn off the backlight
Serial.println("\n--------------------------------------------");
lcd.begin(16, 2);
lcd.print("Welcome!");
lcd.setCursor(0,1);
lcd.print("v1.5");
delay(1500);
lcd.clear();
lcd.print("ENTER SERIAL"); //flash some instructions for 2 seconds
delay(2000);
lcd.clear();
Serial.println("ENTER COMMAND");
//The next few lines of code will handle the commands, like backlight
lcd.setCursor(0,0);
commandIn = Serial.readString();
if (commandIn != "") //white there is something in the buffer
if (commandIn == "allON") //user wants all pins on
Serial.println("ALL PINS HIGH"); //let the user know with serial and the LCD
lcd.clear();
lcd.print("ALL PINS HIGH");
for(int i = 0; i <= 13; i++) //loop through and write to each pin, 0 to 13
pinMode(i, OUTPUT); //make sure each pin is counted as an output
digitalWrite(i, HIGH);
if (commandIn == "allOFF") //user wants all pins off
Serial.println("ALL PINS LOW");
lcd.clear();
lcd.print("ALL PINS LOW");
for(int i = 0; i <= 13; i++)//do the same thing as above, but turn the pins off
pinMode(i, OUTPUT);
digitalWrite(i, LOW);
if (commandIn == "backlightON") //user wants the backlight on
digitalWrite(backlight, HIGH); //turn on the backlight and show some info.
lcd.clear();
lcd.print("BACKLIGHT ON");
lcd.clear();
Serial.println("BACKLIGHT ON");
if (commandIn == "backlightOFF")
digitalWrite(backlight, LOW); //turn off the backlight and show some info.
lcd.clear();
lcd.print("BACKLIGHT OFF");
lcd.clear();
Serial.println("BACKLIGHT OFF");
//ask the forum, im stuck on this. For now, move on
if (commandIn == "allIN") //the user wants all pins to be inputs
Serial.println("ALL PINS ARE INPUTS"); //let the user know with serial and the LCD
lcd.clear();
lcd.print("ALL PINS");
lcd.setCursor(0,1);
lcd.print("INPUTS");
pinMode(i, INPUT); //make sure each pin is counted as an input
if (commandIn == "allOUT") //all pins to be outputs, the defualt
Serial.println("ALL PINS ARE OUTPUTS"); //let the user know with serial and the LCD
lcd.clear();
lcd.setCursor(0,1);
lcd.print("OUTPUTS");
pinMode(i, OUTPUT); //make sure each pin is counted as an input
if (commandIn == "readAll") //display a summary of the states
Serial.println("SUMMARY: 13 PINS READ");
for(int i = 0; i <= 13; i++) //loop through and read the pins
pinRead = digitalRead(i);
if (pinRead == 1) //the pin is high
Serial.print("PIN: ");
Serial.print(i);
Serial.println(" | STATE: HIGH");
if (pinRead == 0) //the pin is low
Serial.print(i);
Serial.println(" | STATE: LOW");
Serial_Controlled_PWM.ino (6.14 KB)
