[resolved]using button to select function
hello,I want to control servo motor by potentiometer or by 02 buttons (up and down),
so, I use one button to to select function
I made this code but it doesn't work correctely .
where is the problem?
#include<Servo.h>
int pot = 0;
int pos = 0 ;
int inPin = 8;
int outPin = 13;
int reading;
int previous = LOW;
long time = 0;
long debounce = 200;
Servo servo;
  pinMode(inPin, INPUT);
  pinMode(outPin, OUTPUT);
 pinMode(6, INPUT);
 pinMode(7, INPUT);
 servo.attach(9);
reading = digitalRead(inPin);
  if (reading == HIGH && previous == LOW && millis() - time > debounce){
   if (poss ())
     pott ();
  poss ();
    time = millis();
  previous = reading;
void pott (){
  pot =(analogRead(A0),0,1023,0,180);
  servo.write(pot);
bool poss (){
  while (digitalRead(6) == HIGH && pos < 180  ) {
   pos++;
   servo.write(pos);
   delay (50);
 while (digitalRead(7) == HIGH && pos > 0 ) {
   pos--;
   servo.write(pos);
   delay (50);
Ever heard of serial monitor :wink: Use it for debugging by using Serial.println statements in strategic places.
And poss() is supposed to return a bool; you don't return anything specifically so it will return garbage.
youceforo:
I made this code but it doesn't work correctely . );
What exactly does this mean?
dougp:
when I press the push button to select potentiometer ,the servo motor doesn't work.
What exactly does that mean?
AWOL:
Probably that poss() 'returns' garbage :slight_smile:
AWOL:
when I press the select button and I change the value of potentiometer ,it doesn't move( it doen't make any angle),
but when I press the select button again to change from potentiometer to digital's push button ,the motor works .
I think ,if you have another code to change state from potentiometer to digital's pin ,post it ,
that will help me .
+1 for adding Serial.print statements to see what's going on at runtime.
The next thing I'd do is separate the debouncing from the reading compares
if(millis() - time > debounce){
if (reading == HIGH && previous == LOW){
// do stuff
or something
Finaly I resolved my problem, thanks for your time.
this is final code :
#include<Servo.h>
int pot = 0;
int pos ;
int state = 1;
int inPin = 8;
int reading;
int previous = LOW;
long time = 0;
Servo servo;
 pinMode(6, INPUT);
 pinMode(7, INPUT);
 servo.attach(9);
   if (state==1)
     state = 0;
  state = 1;
    time = millis();
  previous = reading;
 switch (state) {
    case 0:
     poss ();
    case 1:
    pott ();
   pos = pot;
    default:
void pott (){
  pot = map(analogRead(A0),0,1023,0,180);
     servo.write(pot);
   delay(20);}
void poss (){
  while (digitalRead(6) == HIGH &&pos < 180  ) {
   pos++;
   servo.write(pos);
   delay (50);
   pos--;
   servo.write(pos);
   delay (50);
