Resolving Error "Error compiling for board ESP32-WROOM-DA Module"
While uploading code to my ESP32 board I encountered the following error.
"Error compiling for board ESP32-WROOM-DA Module."
Regular codes upload fine.
Searching for solutions I discovered that this problem is common to ESP32 boards when trying to communicate to external devices using Serial Communication..
The advised solution on the above page led me to a GitHub page, but I am not able to follow what they are talking in language which is absolutely alien to my ears.
In this comment the OP says that he copied the file from the zip folder downloaded from GitHub to this path C:\Users\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2, but this path doesn't exist in my computer. I don't know where to paste this file and what to do next after that.
Someone please guide.
UPDATE 1
I am trying to communicate to a LCD.
Below is the code which failed to upload to my board.
#include <Arduino.h>
const byte rxPin = 16; //rx2
const byte txPin = 17; //tx2
HardwareSerial dwin(1);
unsigned char Buffer[9];
#define XX_add   0x61
unsigned char   XX[8] = {0x5a, 0xa5, 0x05, 0x82, XX_add , 0x00, 0x00, 0x00};
  dwin.begin(115200, SERIAL_8N1, rxPin, txPin);
  sensor_data();
void sensor_data()
  XX[6] = highByte(00.00);
  XX[7] = lowByte(00.00);
  dwin.write(XX, 8);
The error message is too large to post here, posting it below in comments.
UPDATE 2 :
So I found the path in my computer, and pasted the folder here C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\arduino-esp32-1.0.3-rc1, but for the OP on GitHub it had worked, for me it still doesn't.
This is where I have pasted the folder.
have a read of how-to-get-the-best-out-of-this-forum
not sure what software you are having problems with - is it EspSoftwareSerial? I have used it on ESP8266 devices without problems
post the code which gave you the error in post 1 - select < CODE/ > and paste the code or text where it says “type or paste code here”
also post the full error message?
Hi, I have updated my question. Below is the error message.
Arduino: 1.8.19 (Windows 10), Board: "ESP32-WROOM-DA Module, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, Core 1, Core 1, None, Disabled"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Lenovo\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Lenovo\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Lenovo\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32da:PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,LoopCore=1,EventsCore=1,DebugLevel=none,EraseFlash=none -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\Lenovo\AppData\Local\Temp\arduino_build_662018 -warnings=none -build-cache C:\Users\Lenovo\AppData\Local\Temp\arduino_cache_733774 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.dfu-util.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.esptool_py.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5.1 -prefs=runtime.tools.esptool_py-4.5.1.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5.1 -prefs=runtime.tools.mklittlefs.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.xtensa-esp-elf-gdb-11.2_20220823.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.riscv32-esp-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.openocd-esp32.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.11.0-esp32-20221026 -prefs=runtime.tools.openocd-esp32-v0.11.0-esp32-20221026.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.11.0-esp32-20221026 -prefs=runtime.tools.riscv32-esp-elf-gdb.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.riscv32-esp-elf-gdb-11.2_20220823.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\11.2_20220823 -verbose C:\Users\Lenovo\Documents\Arduino\LCD\LCD.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Lenovo\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Lenovo\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Lenovo\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32da:PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,LoopCore=1,EventsCore=1,DebugLevel=none,EraseFlash=none -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\Lenovo\AppData\Local\Temp\arduino_build_662018 -warnings=none -build-cache C:\Users\Lenovo\AppData\Local\Temp\arduino_cache_733774 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.dfu-util.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.esptool_py.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5.1 -prefs=runtime.tools.esptool_py-4.5.1.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5.1 -prefs=runtime.tools.mklittlefs.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.xtensa-esp-elf-gdb-11.2_20220823.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.riscv32-esp-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.openocd-esp32.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.11.0-esp32-20221026 -prefs=runtime.tools.openocd-esp32-v0.11.0-esp32-20221026.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.11.0-esp32-20221026 -prefs=runtime.tools.riscv32-esp-elf-gdb.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.riscv32-esp-elf-gdb-11.2_20220823.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\11.2_20220823 -verbose C:\Users\Lenovo\Documents\Arduino\LCD\LCD.ino
Using board 'esp32da' from platform in folder: C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11
Using core 'esp32' from platform in folder: C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11
cmd /c if exist "C:\\Users\\Lenovo\\Documents\\Arduino\\LCD\\partitions.csv" COPY /y "C:\\Users\\Lenovo\\Documents\\Arduino\\LCD\\partitions.csv" "C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018\\partitions.csv"
cmd /c if not exist "C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018\\partitions.csv" if exist "C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\variants\\esp32da\\partitions.csv" COPY "C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\variants\\esp32da\\partitions.csv" "C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018\\partitions.csv"
cmd /c if not exist "C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018\\partitions.csv" COPY "C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\tools\\partitions\\default.csv" "C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018\\partitions.csv"
cmd /c IF EXIST "C:\\Users\\Lenovo\\Documents\\Arduino\\LCD\\bootloader.bin" ( COPY /y "C:\\Users\\Lenovo\\Documents\\Arduino\\LCD\\bootloader.bin" "C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018\\LCD.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\variants\\esp32da\\bootloader.bin" ( COPY "C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\variants\\esp32da\\bootloader.bin" "C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018\\LCD.ino.bootloader.bin" ) ELSE ( "C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.5.1/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018\\LCD.ino.bootloader.bin" "C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\tools\\sdk\\esp32\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.5.1
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
cmd /c if exist "C:\\Users\\Lenovo\\Documents\\Arduino\\LCD\\build_opt.h" COPY /y "C:\\Users\\Lenovo\\Documents\\Arduino\\LCD\\build_opt.h" "C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018\\build_opt.h"
cmd /c if not exist "C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018\\build_opt.h" type nul > "C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018\\build_opt.h"
cmd /c type nul > "C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018/file_opts"
Detecting libraries used...
"C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.5\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/log/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/console" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018/build_opt.h" "@C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018/file_opts" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\cores\\esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\variants\\esp32da" "C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018\\sketch\\LCD.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.5\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/log/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/console" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018/build_opt.h" "@C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018/file_opts" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\cores\\esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\variants\\esp32da" "C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018\\sketch\\LCD.ino.cpp" -o "C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.5\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/log/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/console" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -MMD -c -w -Os -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018/build_opt.h" "@C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018/file_opts" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\cores\\esp32" "-IC:\\Users\\Lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\variants\\esp32da" "C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018\\sketch\\LCD.ino.cpp" -o "C:\\Users\\Lenovo\\AppData\\Local\\Temp\\arduino_build_662018\\sketch\\LCD.ino.cpp.o"
In file included from C:\Users\Lenovo\Documents\Arduino\LCD\LCD.ino:1:
C:\Users\Lenovo\Documents\Arduino\LCD\LCD.ino: In function 'void sensor_data()':
C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\cores\esp32/Arduino.h:93:37: error: invalid operands of types 'double' and 'int' to binary 'operator>>'
 #define highByte(w) ((uint8_t) ((w) >> 8))
C:\Users\Lenovo\Documents\Arduino\LCD\LCD.ino:29:11: note: in expansion of macro 'highByte'
   XX[6] = highByte(00.00);
C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\cores\esp32/Arduino.h:92:36: error: invalid operands of types 'double' and 'int' to binary 'operator&'
 #define lowByte(w) ((uint8_t) ((w) & 0xff))
C:\Users\Lenovo\Documents\Arduino\LCD\LCD.ino:30:11: note: in expansion of macro 'lowByte'
   XX[7] = lowByte(00.00);
exit status 1
Error compiling for board ESP32-WROOM-DA Module.
looking at highByte() documentation it is vauge but it appears it only works on integer type parameters
it is because HighByte uses logical shift which does not work on double types, e.g.
  XX[6] = highByte(0.0);
gives error message
e.g. if i change you code to integer parameters
  XX[6] = highByte(0);
  XX[7] = lowByte(10);
it compiles OK
what are you attempting to do? change a double to a byte array?
what sensor are you attempting to communicate with?
also remember on a ESP32 the sizeof() a double is 8-bytes
Yeah it compiled ok. Thanks for identifying the problem.
Yes its a double value which I am trying to pass to the LCD to print on the LCD.
Here is where I found the code snippets used above, but the values they are passing are all integers.
So how do I pass Double values? What should I modify?
Most LCD libraries inherit from the Print class which already knows how to print a double type variable.
There is not much examples on how to work this particular LCD type. I just found this one example which came close to my requirements, and don't see them using the easy way. I have read people's complaints that this particular LCD asks for very technical work. Basically, what I am saying is I don't know how to just ask it to "print".
So how do we communicate Double values to the LCD?
looking at the Serial Communication Protocol document the communications protocol is fairly straightforward but will require a lot of work
it would be worth asking dwin-global if they have any example C library or code you could adapt for the ESP32
think what you will have to do it to convert you float/double values into text using a char array which can then be written using the appropriate serial commands to the LCD, e.g.
  Serial.println("\n\nfloat to char array");
  float pi=3.1415926;
  char text[100]={0};
  snprintf(text,100,"pi = %f\n", pi);
  Serial.println(text);
void loop() {}
when run displays
float to char array
pi = 3.141593
I don't think they allow me to bring up characters. Here is the options they give of what types of variables I can bring in.
@dwinhmi please share any example C library or code we could adapt for ESP32. We are trying to send Double variable to DWIN LCD using "Data Variable Display" in the DGUS Software.
Looking at the Comms protocol linked by @horace, it doesn't seem that difficult. You'd build up the transfer buffer in a similar manner to what you have except noting that a 'double' is 8 bytes long. The one thing that could get sticky is that I noticed the protocol appears to use the Big Endian convention while ESP32 uses Little Endian. I'm surmising this from one of the examples given in the Comms document:
If it were my project, I'd play with the two possible byte orderings (Big / Little) and monitor the signal on the serial line with a logic analyzer. Swap things around till the serial stream is correct and the LCD display is correct.
Per my post above, it might be something like:
constexpr uint8_t payloadLocation = 6;
constexpr size_t bufferSize = payloadLocation + sizeof(double);
constexpr uint8_t headerByte0 = 0x5A;
constexpr uint8_t headerByte1 = 0xA5;
constexpr uint8_t byteCount = 3 + sizeof(double);
constexpr uint8_t command  = 0x82;
constexpr uint8_t vpByte0 = 0x61;
constexpr uint8_t vpByte1 = 0x00;
uint8_t floatBuffer[bufferSize] = {headerByte0, headerByte1, byteCount, command, vpByte0, vpByte1};
AND THEN .....
  // ----------- For Little Endian Byte Ordering -----------
  double doubleData = 3673.23;
  memcpy(floatBuffer + payloadLocation, &doubleData , sizeof(double));
  dwin.write(floatBuffer, bufferSize);
OR THIS .....
  // ----------- For Big Endian Byte Ordering -----------
  uint8_t * const dataPtr = reinterpret_cast<uint8_t *> (&doubleData);
  for (uint8_t index = 0; index < sizeof(float); index++) {
    *(floatBuffer + payloadLocation + index) = *(dataPtr + sizeof(double) - index - 1);
Hi, thanks for this. I have been going through it and have perhaps understood 5% of what you are doing here (I am not big into coding).
I tried both the iterations of what you did but none seems to be printing anything onto the screen. Below are my sketches. Can you see if I have done something wrong?
Sketch for Little Endian
#include <Arduino.h>
const byte rxPin = 16; //rx2
const byte txPin = 17; //tx2
HardwareSerial dwin(1);
  dwin.begin(115200, SERIAL_8N1, rxPin, txPin);
  //Serial.begin(115200);
  sensor_data();
void sensor_data()
  double doubleData = 73.23;
Sketch for big endian.
  sensor_data();
void sensor_data()
My next step would be:
