I'm new to the using Arduino. recently bought the Arduino Uno with other supplies. I've managed to set up everything. I'm trying to write programs to the chip in Assembly however I keep getting this message. Everything seems to work (the Arduino lights up, showing the power LED and pin 13). I can also run the blink program on the IDE and is works fine. I've been searching this problem but all the solutions do not seem to work.
MH01:
That's doubtful. You are not "running" the program from the IDE. It has to be uploaded first. If other uploads are failing, so is the blink example.
Quick test, change the delay(1000) to delay(250). Hit Upload. If you don't see the flash rate change, then the program isn't getting uploaded.
Check the obvious things, different cable, proper drivers, correct port and board are selected. Then enable verbose output in preferences, copy/paste results here (with code tags.)
I'm sure the flash rate did the change. I don't have another cable atm but i'm sure the port is correct and also the board is correct (Arduino/Genuino Uno selected in the IDE). I'm trying to write assembly using notepad and cmd, this is where I get the error.
The following is the code outputted by the IDE when I run the blink program.
Sketch uses 1,030 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
C:\Program Files\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM7 -b115200 -D -Uflash:w:C:\Users\Ahmad\AppData\Local\Temp\build08e4957f02c018eb579e11ddc64f9701.tmp/Blink.ino.hex:i
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM7
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f
avrdude: reading input file "C:\Users\Ahmad\AppData\Local\Temp\build08e4957f02c018eb579e11ddc64f9701.tmp/Blink.ino.hex"
avrdude: writing flash (1030 bytes):
Writing | ################################################## | 100% 0.21s
avrdude: 1030 bytes of flash written
avrdude: verifying flash memory against C:\Users\Ahmad\AppData\Local\Temp\build08e4957f02c018eb579e11ddc64f9701.tmp/Blink.ino.hex:
avrdude: load data flash data from input file C:\Users\Ahmad\AppData\Local\Temp\build08e4957f02c018eb579e11ddc64f9701.tmp/Blink.ino.hex:
avrdude: input file C:\Users\Ahmad\AppData\Local\Temp\build08e4957f02c018eb579e11ddc64f9701.tmp/Blink.ino.hex contains 1030 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.16s
avrdude: verifying ...
avrdude: 1030 bytes of flash verified
avrdude done. Thank you.
My original problem what not that the blink program wasn't working, it was that this error kept popping up when I was attempting to write my assembly program to the memory. I simply used the blink program to see if the uno was working and it did work.
However, since my last post, the blink program is no longer working and although the Uno states that it is on com7, it doesn't seem to work.
The following code:
Using Port : COM7
avrdude: ser_open(): can't open device "\\.\COM7": The system cannot find the file specified.
