Result is not what it should be
Hi, I'm trying to find average of an array using function. But the average should be 5.5, instead it shows 5.00. I don't know if anything wrong with my code. Thank you.
int Array[10] = { 8, 7, 6, 3, 2, 1, 5, 4, 9, 10 };
double Result;
double avg;
  double ArrayAverage(int sum) {
    Result = sum/10;
    return Result;
  int sum=0;
  for (int index=0; index<=9; index++) {
    sum = sum + Array[index];
  Result = ArrayAverage(sum);
  Serial.print("Result: ");
  Serial.print(Result);
you are doing integer maths, so sum/10 is an integer
do sum/10.0
(your function is not really useful as the number of entries is fixed)
(double)sum/10
