Results of DHT22 and MS5607 on board a high altitude balloon
Hi!
I thought I would share my results with the sensors I used on board a high altitude balloon. I had a DHT22 humidity/temperature sensor and an MS5607 altimeter module from Parallax both hooked up to an Arduino Mega with an SD card shield. I also had an Adafruit Ultimate GPS Data Logging Shield stacked on a Mega, but alas, the SDA cable came loose during launch and no data was recorded from that one.
I used a 3kg balloon from Hwoyee and roughly 200 cubic feet of hydrogen to reach a peak altitude of 115,900 feet over south Florida on Memorial Weekend. The payload included a 3-feet parachute, a GPS gimbal (with a SPOT personal tracker), a mini GPS GSM tracker, as well as two GoPro cameras and a Canon Powershot. Unfortunately, the GoPros both failed, but the Canon took some amazing pictures.
You could say the flight was a mixed success because of what happened with the GPS shield and the GoPros, but the pictures that came back were worth.
Attached are a few pictures from the flight as well as the data that was recorded during the flight with some post-flight processing for graphs, altitude calculations, etc.
This is the code I used for the temperature/humidity and pressure sensors. As you'll notice I also had an LCD screen hooked up for quick confirmation of reading during pre-launch:
#include <Wire.h>
#include <DHT.h>
#include <SPI.h>
#include <SD.h>
#include "LiquidCrystal.h"
#define DHTPIN 2     // what pin we're connected to
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11   // DHT 11
#define DHTTYPE DHT22   // DHT 22  (AM2302)
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
DHT dht(DHTPIN, DHTTYPE);
#define ADDRESS 0x76 //0x77
uint32_t D1 = 0;
uint32_t D2 = 0;
int64_t dT = 0;
int32_t TEMP = 0;
int64_t OFF = 0;
int64_t SENS = 0;
int32_t P = 0;
uint16_t C[7];
const int chipSelect = 4;
float Temperature;
float Pressure;
LiquidCrystal lcd(4, 3, 5);
#define visualPin 6
int ledState = LOW;             // ledState used to set the LED
long previousMillis = 0;
long interval = 10000;
long intervalShort = 150;
// Disable internal pullups, 10Kohms are on the breakout
PORTC |= (1 << 4);
PORTC |= (1 << 5);
 Wire.begin();
 Serial.begin(9600); //9600 changed 'cos of timing?
 delay(100);
  Serial.println("DHT22 with SD Logging!");
  pinMode(10, OUTPUT);
  pinMode(visualPin, OUTPUT);
  if (!SD.begin(chipSelect)) {
  Serial.println("Card failed, or not present");
  return;
    Serial.println("card initialized.");
  delay(2000);
  dht.begin();
  #define LED 13
 initial(ADDRESS);
   lcd.begin(16, 2);
     lcd.print("AETHER II");
   File dataFile = SD.open("datalog.csv", FILE_WRITE);
  // Wait a few seconds between measurements.
  delay(4850);
  float h = dht.readHumidity();
  // Read temperature as Celsius
  float t = dht.readTemperature();
  // Read temperature as Fahrenheit
  float f = dht.readTemperature(true);
    if (isnan(h) || isnan(t) || isnan(f)) {
    Serial.println("Failed to read from DHT sensor!");
    return;
  Serial.print("Humidity: ");
  Serial.print(h);
  Serial.print(" %\t");
  Serial.print("Temperature: ");
  Serial.print(t);
  Serial.print(" *C ");
  Serial.print(f);
  Serial.print(" *F\%");
 D1 = getVal(ADDRESS, 0x48); // Pressure raw
 D2 = getVal(ADDRESS, 0x58);// Temperature raw
 dT   = D2 - (uint32_t)C[5] *pow(2,8);
 OFF  = (int64_t)C[2] * pow(2,17) + ((dT * C[4])/pow(2,6));
 SENS = (int32_t)C[1] *pow(2,16) + ((dT * C[3])/pow(2,7));
 TEMP = ((int64_t)dT * (int64_t)C[6] / 8388608) + 2000;
 if(TEMP < 2000) // if temperature lower than 20 Celsius
   int32_t T1    = 0;
   int64_t OFF1  = 0;
   int64_t SENS1 = 0;
   T1    = pow(dT, 2) / 2147483648;
   OFF1  = 61 * pow((TEMP - 2000), 2) / 16;
   SENS1 = 2 * pow((TEMP - 2000), 2);
   if(TEMP < -1500) // if temperature lower than -15 Celsius
     OFF1  = OFF1 + 15 * pow((TEMP + 1500), 2);
     SENS1 = SENS1 + 8 * pow((TEMP + 1500), 2);
   TEMP -= T1;
   OFF -= OFF1;
   SENS -= SENS1;
 Temperature = (float)TEMP / 100;
 P  = ((int64_t)D1 * SENS / 2097152 - OFF) / 32768;
 Pressure = (float)P / 100;
 Serial.print("     Actual TEMP= ");
 Serial.print(Temperature);
 Serial.print("      Actual PRESSURE= ");
 Serial.print(Pressure);
 Serial.print(" RAW Temp D2=  ");
 Serial.print(D2);
 Serial.print(" RAW Pressure D1=  ");
 Serial.println(D1);
//  Serial.print(" dT=  ");
//  Serial.println(dT); can't print int64_t size values
 Serial.print(" C1 = ");
 Serial.println(C[1]);
 Serial.print(" C2 = ");
 Serial.println(C[2]);
 Serial.print(" C3 = ");
 Serial.println(C[3]);
 Serial.print(" C4 = ");
 Serial.println(C[4]);
 Serial.print(" C5 = ");
 Serial.println(C[5]);
 Serial.print(" C6 = ");
 Serial.println(C[6]);
//  Serial.print(" C7 = ");
//  Serial.println(C[7]);
lcd.setCursor(0, 0);
lcd.print("mBar: ");
lcd.setCursor(7,0);
lcd.print(Pressure);
lcd.setCursor(0,1);
lcd.print("Cels: ");
lcd.setCursor(6,1);
lcd.print(Temperature);
  if(dataFile){
  String dataString = String(h) + ", " + String(t) + ", " + String(f) + "," + String(Pressure) + "," + String(Temperature) + "," + String(D1)+ "," + String (D2);
  dataFile.println(dataString);
  dataFile.close();
  if(t && Pressure && currentMillis - previousMillis > interval) {
    // save the last time you blinked the LED
digitalWrite(visualPin,HIGH);}
delay(150);
digitalWrite(visualPin,LOW);
  else{Serial.println("Couldn't access file");}
long getVal(int address, byte code)
 unsigned long ret = 0;
 Wire.beginTransmission(address);
 Wire.write(code);
 Wire.endTransmission();
 delay(10);
 // start read sequence
 Wire.write((byte) 0x00);
 Wire.requestFrom(address, (int)3);
 if (Wire.available() >= 3)
   ret = Wire.read() * (unsigned long)65536 + Wire.read() * (unsigned long)256 + Wire.read();
 else {
   ret = -1;
 return ret;
void initial(uint8_t address)
 Serial.println("PROM COEFFICIENTS");
 Wire.write(0x1E); // reset
 delay(10);
 for (int i=0; i<6  ; i++) {
   Wire.write(0xA2 + (i * 2));
   Wire.requestFrom(address, (uint8_t) 6);
   delay(1);
   if(Wire.available())
      C[i+1] = Wire.read() << 8 | Wire.read();
   else {
     Serial.println("Error reading PROM 1"); // error reading the PROM or communicating with the device
   Serial.println(C[i+1]);
Apparently the excel file can't be attached and the pictures are too large. I'll be posting a link to a website hosting these soon.
Well, here's the video I made. I'll be posting the excel file with the data today.
Superb video!! Great shots!
do you also have shots made during the way down?
-55C is really cold -> didn't you include a heater?
what amazed me was I did not notice air-plane tracks on the pictures.
robtillaart:
Thanks!
Unfortunately we only have like 20 shots of the descent. You'll notice there's two pictures towards the end where you can see this orange thing in front of the camera. That's the GPS gimbal tumbling down with the rest of the payload before the parachute took over.
I programmed the camera to start taking pictures about an hour into the flight. This is because I knew the battery on the camera would only last about 2.5 hours whereas the flight would last upwards of 3.5. So, I wanted to make sure the apogee of the flight would have pictures.
Although -55 celsius is extremely cold. Inside the capsule it was only -2. The cameras outside did pretty good considering the temperatures, and this is probably because they were all running on Lithium Ion batteries which withstand the cold pretty well.
Here are some of the better images recovered from the flight:
High Altitude Balloon over South Florida - Imgur?
