resume here after a break? #library
found this library online. But how can I add to a resume here after a break?
#pragma once
#ifndef COUNTIMER_H
#define COUNTIMER_H
#if defined(ARDUINO) && ARDUINO >= 100
#include <Arduino.h>
#else
#include <WProgram.h>
#endif
#define COUNTIMER_MAX_HOURS 99
#define COUNTIMER_MAX_MINUTES_SECONDS 59
typedef void(*timer_callback)(void);
class Countimer
public:
Countimer();
~Countimer();
enum CountType
COUNT_NONE = 0,
COUNT_UP = 1,
COUNT_DOWN = 2
// Set up counter time(hours, minutes, seconds), count mode and function to execute if count is completed.
void setCounter(uint8_t hours, uint8_t minutes, uint8_t seconds, CountType countType, timer_callback onComplete);
// Change existing counter time preset(hours, minutes, seconds).
void setCounter(uint8_t hours, uint8_t minutes, uint8_t seconds);
// Returns timer’s current hours.
uint8_t getCurrentHours();
// Returns timer’s current minutes.
uint8_t getCurrentMinutes();
// Returns timer’s current seconds.
uint8_t getCurrentSeconds();
void setInterval(timer_callback callback, uint32_t interval);
// Returns current timer as formatted string HH:MM:SS
char* getCurrentTime();
// Returns true if counter is completed, otherwise returns false.
bool isCounterCompleted();
// Returns true if counter is still running, otherwise returns false.
bool isCounterRunning();
// Returns true if timer is stopped, otherwise returns false.
bool isStopped();
// Run timer. This is main method.
// If you want to start timer after run, you have to invoke start() method.
void run();
// Starting timer.
void start();
// Stopping timer.
void stop();
// Pausing timer.
void pause();
// Restart timer.
void restart();
private:
// Counting up timer.
void countDown();
// Counting down timer.
void countUp();
uint32_t _interval;
unsigned long _previousMillis;
// Stores current counter value in milliseconds.
unsigned long _currentCountTime;
unsigned long _startCountTime;
// Stores cached user’s time.
unsigned long _countTime;
// Function to execute.
timer_callback _callback;
// Function to execute when timer is complete.
timer_callback _onComplete;
bool _isCounterCompleted;
bool _isStopped;
char _formatted_time[9];
CountType _countType;
#endif
de button </> so your code looks like this and is easy to copy to a text editor. See How to use the Forum
After what break?
Post a complete program.
…R
