Hello
I have an Adafruiit 0.96" display... used them many times before. Connected on I2c to a Pro Mini.
However, I have other devices on the same bus. This seems to be causing un-required grief.
At the beginning of the program, I declare the usual:
Adafruit_SSD1306 display(OLED_RESET);
display.begin(SSD1306_SWITCHCAPVCC, 0x3c);
OLED_RESET is set to -1 by the way.
I can write to the screen fine, but once I access anything else on the I2C bus (such as a pair of MCP23017s), then screen then will not accept any further commands without the original Reset and display.begin being declared again. Never had to do that before.
Further more, if there is a line to say draw a line in the code in it's own sub-routine, it won't compile without those 2 commands first (throws up a display was not declared error).
So I end up with the reset and begin commands many times over.
Does anyone know of a Oled resume type command for the I2C bus? Doesn't seem right to use display.begin every time.
Furthermore, when I call the displaybegin, it recalls the Adafruit logo.... not wanted!
Any ideas?
When I get home, I will upload the code
