Hello all...
maybe 9 months ago I had nice momentum with a Feather Huzzah project that shows games and demonstrations on a TFT screen, etc.
I let it sit for 9 months, and now I tried to compile it with the new IDE (previously i had 1.8.10, now I have 1.8.12) ... and lots of library and board updates... and now my Huzzah project will not load.
I am hoping that someone here may be able to recognize the error message and guide me towards what is probably a commonsense step to make it work again...
I will paste below (1) the compiler error messages and (2) the full project code.
Apologies if this is either annoying or incomplete, or both -- HUGE THANKS -- Eric
===== LAST LINES OF THE COMPILE ERRORS ... *** BUT FOR FULL ERRORS SET SEE THIS URL: HUZ COMPILE ERRORS - Pastebin.com
Arduino: 1.8.12 (Mac OS X), Board: "Adafruit Feather HUZZAH ESP8266, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
... CHOPPED OUT A LOT DUE TO CHAR LIMIT, FOR FULL ERR SET SEE PASTEBIN LINK ABOVE ...
/Users/ericstephan/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/Users/ericstephan/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.1/tools/sdk/include -I/Users/ericstephan/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.1/tools/sdk/lwip2/include -I/Users/ericstephan/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.1/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/fs/qn6sgg0j5xs8vyp7bv60wg7w0000gn/T/arduino_build_929488/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10812 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DFLASHMODE_QIO -DESP8266 -I/Users/ericstephan/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.1/cores/esp8266 -I/Users/ericstephan/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.1/variants/adafruit "-I/Users/ericstephan/Dropbox/L- PROGRAMMING/Arduino/libraries/Adafruit_GFX_Library" "-I/Users/ericstephan/Dropbox/L- PROGRAMMING/Arduino/libraries/Adafruit_ILI9341" -I/Users/ericstephan/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.1/libraries/SPI "/Users/ericstephan/Dropbox/L- PROGRAMMING/Arduino/libraries/Adafruit_GFX_Library/Adafruit_MonoOLED.cpp" -o /dev/null
Alternatives for Adafruit_I2CDevice.h: []
ResolveLibrary(Adafruit_I2CDevice.h)
-> candidates: []
In file included from /Users/ericstephan/Dropbox/L- PROGRAMMING/Arduino/libraries/Adafruit_GFX_Library/Adafruit_MonoOLED.cpp:18:0:
/Users/ericstephan/Dropbox/L- PROGRAMMING/Arduino/libraries/Adafruit_GFX_Library/Adafruit_MonoOLED.h:28:32: fatal error: Adafruit_I2CDevice.h: No such file or directory
#include <Adafruit_I2CDevice.h>
compilation terminated.
Using library Adafruit_GFX_Library at version 1.8.0 in folder: /Users/ericstephan/Dropbox/L- PROGRAMMING/Arduino/libraries/Adafruit_GFX_Library
Using library Adafruit_ILI9341 at version 1.5.5 in folder: /Users/ericstephan/Dropbox/L- PROGRAMMING/Arduino/libraries/Adafruit_ILI9341
Using library SPI at version 1.0 in folder: /Users/ericstephan/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.1/libraries/SPI
exit status 1
Error compiling for board Adafruit Feather HUZZAH ESP8266.
==== FIRST LINES OF THE PROJECT CODE, CHOPPED DUE TO CHAR LIMIT
go/* huzzah and 240 x 320 ili9341... a match made in heaven */
#include <Adafruit_GFX.h> // Include core graphics library
#include <Adafruit_ILI9341.h> // Include Adafruit_ILI9341 library to drive the display
// Declare pins for the display:
#define TFT_DC 16 // WAS ORIG 9
#define TFT_RST 12 // WAS ORIG 8~ // You can also connect this to the Arduino reset in which case, set this #define pin to -1!
#define TFT_CS 15 // WAS ORIG 10~
// The rest of the pins are pre-selected as the default hardware SPI for Arduino Uno (SCK = 13 and SDA = 11)
// Create display:
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_RST);
//#include <Fonts/FreeSerif24pt7b.h> // Add a custom font
const int screenwidth = 240;
const int screenheight = 320;
//const int numdotrows = 20, numdotcols = 15;
//const int numdotrows = 4*5, numdotcols = 3*5;
//const int numdotrows = 4, numdotcols = 3;
const int numdotrows = 320/6, numdotcols = 240/6; //8 good 7 good 6 good... 40x53
const int dotwidth = screenwidth / numdotcols;
const int dotheight = screenheight / numdotrows;
const int maxmenu = 9;
int menuitem=0;
bool firstrun = true;
String menunames[] = {"a poem ","pong ","life is goody ", "rocket circuit ", "dot circuit ", "linear division ","sparkle ","sparkleVi ","ballbot ","terrain "};
float ballx,bally,xvel,yvel; // global ball variables... embarrassing
uint16_t colorof(uint8_t r, uint8_t g, uint8_t b) {
return ((r & 0xF8) << 8) | ((g & 0xFC) << 3) | ((b & 0xF8) >> 3);
// CLASS DOT
class Dot {
........................TRUNCATED DUE TO CHAR LIMITS
