I had this Project working back in 2016. The board stopped working after a friend took it home to show it off. It's been on the bench for some time now.
PaulRB ?
I dusted it off and purchased all new parts. Now the sketch does not compile.
I think it has to do with the IP4 being outdated?
I copied the original sketches from here: Audio fx trigger - #2 by marine_hm
Station Sketch
#include <ESP8266WiFi.h>
const char* ssid = "SoundFx";
const char* password = "Adafruit";
int ledPin = D1;
int triggerPin = D7;
WiFiServer server(80);
delay(10);
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW);
pinMode(triggerPin, OUTPUT);
digitalWrite(triggerPin, HIGH);
// Connect to WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
WiFi.mode(WIFI_STA);
digitalWrite(ledPin, HIGH);
Serial.print(".");
delay(50);
Serial.println("");
Serial.println("WiFi connected");
// Start the server
server.begin();
Serial.print("Server started on ");
// Check if a client has connected
WiFiClient client = server.available();
if (client) {
// Wait until the client sends some data
Serial.println("new client");
while (!client.available()) {
delay(1);
// Read the first line of the request
String request = client.readStringUntil('\r');
Serial.println(request);
client.flush();
// Match the request
int value = LOW;
if (request.indexOf("/LED=ON") != -1) {
digitalWrite(triggerPin, LOW);
value = HIGH;
if (request.indexOf("/LED=OFF") != -1) {
value = LOW;
// Set ledPin according to the request
//digitalWrite(ledPin, value);
// Return the response
client.println("Content-Type: text/html");
client.println(""); // do not forget this one
client.print("Led pin is now: ");
if (value == HIGH) {
client.print("On");
client.print("Off");
client.flush();
client.stop();
Serial.println("Client disonnected");
Serial.println("");
AP Sketch
extern "C" {
#include "user_interface.h"
char apName[] = "SoundFx";
char apPassword[] = "Adafruit";
delay(100);
WiFi.softAP(apName, apPassword);
WiFi.mode(WIFI_AP);
pinMode(D4, INPUT);// not sure what to put here
Serial.println("AP Started");
int value = 0;
int stations = -1;
int stationsNow = wifi_softap_get_station_num();
if (stations != stationsNow) {
stations = stationsNow;
Serial.print("Station count: ");
Serial.println(stations);
int newValue = digitalRead(D4);
if (newValue != value) {
value = newValue;
Serial.print("value=");
Serial.println(value);
struct station_info *stat_info;
struct ip_addr *IPaddress;
unsigned long uintaddress;
Serial.println("Updating connected stations...");
stat_info = wifi_softap_get_station_info();
while (stat_info != NULL) {
IPaddress = &stat_info->ip;
uintaddress = IPaddress->addr;
String host = String(ip4_addr1(&uintaddress)) + "." + ip4_addr2(&uintaddress) + "." + ip4_addr3(&uintaddress) + "." + ip4_addr4(&uintaddress);
Serial.print("connecting to ");
Serial.println(host);
// Use WiFiClient class to create TCP connections
WiFiClient client;
const int httpPort = 80;
if (!client.connect(host.c_str(), httpPort)) {
Serial.println("connection failed");
else {
// We now create a URI for the request
String url;
url = "/LED=ON";
else {
url = "/LED=OFF";
Serial.print("Requesting URL: ");
Serial.println(url);
// This will send the request to the server
client.print(String("GET ") + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
delay(50);
// Read all the lines of the reply from server and print them to Serial
while (client.available()) {
String line = client.readStringUntil('\r');
Serial.print(line);
Serial.println("closing connection");
client.flush();
client.stop();
stat_info = STAILQ_NEXT(stat_info, next);
Serial.println("All connected stations updated.");
Here's the error I get when compiling the AP Sketch
Arduino: 1.8.16 (Windows 7), Board: "LOLIN(WEMOS) D1 mini Pro, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 16MB (FS:14MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\User\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\User\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\User\Documents\Arduino\libraries -fqbn=esp8266:esp8266:d1_mini_pro:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=16M14M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=921600 -vid-pid=1A86_7523 -ide-version=10816 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_157031 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_10756 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.python3.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -verbose C:\Users\User\Documents\Arduino\Test_AP\Test_AP.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\User\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\User\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\User\Documents\Arduino\libraries -fqbn=esp8266:esp8266:d1_mini_pro:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=16M14M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=921600 -vid-pid=1A86_7523 -ide-version=10816 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_157031 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_10756 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.python3.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -verbose C:\Users\User\Documents\Arduino\Test_AP\Test_AP.ino
Using board 'd1_mini_pro' from platform in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2
Using core 'esp8266' from platform in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2
Detecting libraries used...
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINIPRO -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINIPRO\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031\\sketch\\Test_AP.ino.cpp" -o nul
Alternatives for ESP8266WiFi.h: [ESP8266WiFi@1.0]
ResolveLibrary(ESP8266WiFi.h)
-> candidates: [ESP8266WiFi@1.0]
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINIPRO -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINIPRO\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031\\sketch\\Test_AP.ino.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINIPRO -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINIPRO\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src\\BearSSLHelpers.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINIPRO -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINIPRO\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src\\CertStoreBearSSL.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINIPRO -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINIPRO\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src\\ESP8266WiFi.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINIPRO -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINIPRO\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiAP.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINIPRO -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINIPRO\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiGeneric.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINIPRO -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINIPRO\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiGratuitous.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINIPRO -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINIPRO\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiMulti.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINIPRO -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINIPRO\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiSTA-WPS.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINIPRO -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINIPRO\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiSTA.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINIPRO -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINIPRO\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiScan.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINIPRO -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINIPRO\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src\\WiFiClient.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINIPRO -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINIPRO\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src\\WiFiClientSecureBearSSL.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINIPRO -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINIPRO\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src\\WiFiServer.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINIPRO -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINIPRO\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src\\WiFiServerSecureBearSSL.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINIPRO -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINIPRO\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src\\WiFiUdp.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINIPRO -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINIPRO\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src\\enable_wifi_at_boot_time.cpp" -o nul
Generating function prototypes...
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINIPRO -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINIPRO\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031\\sketch\\Test_AP.ino.cpp" -o "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/signing.py" --mode header --publickey "C:\\Users\\User\\Documents\\Arduino\\Test_AP/public.key" --out "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031/core/Updater_Signing.h"
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINIPRO -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINIPRO\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031\\sketch\\Test_AP.ino.cpp" -o "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_157031\\sketch\\Test_AP.ino.cpp.o"
C:\Users\User\Documents\Arduino\Test_AP\Test_AP.ino: In function 'void loop()':
Test_AP:50:19: error: invalid conversion from 'ip4_addr*' to 'ip_addr*' [-fpermissive]
50 | IPaddress = &stat_info->ip;
| ip4_addr*
In file included from C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include/lwip/ip_addr.h:43,
from C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include/ipv4_addr.h:41,
from C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include/user_interface.h:31,
from C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include/glue.h:60,
from C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include/arch/cc.h:61,
from C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include/lwip/arch.h:48,
from C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include/lwip/debug.h:40,
from C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include/lwipopts.h:3632,
from C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include/lwip/opt.h:51,
from C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include/lwip/init.h:40,
from C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266/IPAddress.h:27,
from C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src/ESP8266WiFi.h:31,
from C:\Users\User\Documents\Arduino\Test_AP\Test_AP.ino:1:
C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include/lwip/ip4_addr.h:176:67: error: request for member 'addr' in '* & uintaddress', which is of non-class type 'long unsigned int'
176 | #define ip4_addr_get_byte(ipaddr, idx) (((const u8_t*)(&(ipaddr)->addr))[idx])
C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include/lwip/ip4_addr.h:177:27: note: in expansion of macro 'ip4_addr_get_byte'
177 | #define ip4_addr1(ipaddr) ip4_addr_get_byte(ipaddr, 0)
C:\Users\User\Documents\Arduino\Test_AP\Test_AP.ino:52:28: note: in expansion of macro 'ip4_addr1'
52 | String host = String(ip4_addr1(&uintaddress)) + "." + ip4_addr2(&uintaddress) + "." + ip4_addr3(&uintaddress) + "." + ip4_addr4(&uintaddress);
C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include/lwip/ip4_addr.h:178:27: note: in expansion of macro 'ip4_addr_get_byte'
178 | #define ip4_addr2(ipaddr) ip4_addr_get_byte(ipaddr, 1)
C:\Users\User\Documents\Arduino\Test_AP\Test_AP.ino:52:61: note: in expansion of macro 'ip4_addr2'
C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include/lwip/ip4_addr.h:179:27: note: in expansion of macro 'ip4_addr_get_byte'
179 | #define ip4_addr3(ipaddr) ip4_addr_get_byte(ipaddr, 2)
C:\Users\User\Documents\Arduino\Test_AP\Test_AP.ino:52:93: note: in expansion of macro 'ip4_addr3'
C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include/lwip/ip4_addr.h:180:27: note: in expansion of macro 'ip4_addr_get_byte'
180 | #define ip4_addr4(ipaddr) ip4_addr_get_byte(ipaddr, 3)
C:\Users\User\Documents\Arduino\Test_AP\Test_AP.ino:52:125: note: in expansion of macro 'ip4_addr4'
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi
exit status 1
