Retrieve emails using Arduino
Hi, I would like to make a program for arduino that can control the lights in my home using an Ethernet Shield. I was thinking that I could have it retrieve emails from gmail (I would make a separate email address for it) and then turn on the appropriate light with a wireless appliance switch. I know how to connect an Arduino to the remote control for the appliance switches, but i do not know how to make the ethernet shield retrieve an email. I read on another forum that you could use a webserver and PHP to send a HTTP POST to the arduino, but I do not know how to use PHP, so I would like to avoid learning another programming language if I can. I would also like to avoid using my computer with the Arduino as I don't want to have to leave my computer on if I want to turn on the lights in my home. Any help would be greatly appreciated.
-Caleb
You can access your Gmail account directly via POP using any email client.
Arduino support SSL is none. No go.
Is it possible to use any other webmail service that is not ssl?
calebgerth99:
If your mail provider doesn't require SSL then you have a chance, but you would need to write/find code implementing the client support for whatever mail protocol and authentication mechanism you needed to use. Unfortunately there are a lot to choose from, fortunately most of them are quite simple.
What if i used www.tropo.com. Then I could control the lights from my phone with a text message or a call. I still need guidance on how to get a tropo script to send the information to the Arduino. Any help would be greatly appreciated.
