Hello,
I was looking at designing a solar current data logger such that this current is used to provide charge to a 6000mah lipo battery.
I am currently monitoring the current charge of the battery and overall solar current and storing this data on a 32 GB SD card while transmitting this value with bluetooth via a JSON file so it can update on my phone application.
The reason for the SD card was to be able to retrieve the last saved values once the battery runs out of charge and turns off the Arduino to be able to better calculate the current produced by the Solar Panel.
My question is if there's a way to retrieve the last saved values of my SD card and send them as a JSON file to my app??
My values are represented like this:
Initializing SD card...initialization done.
done.
TEST1.CSV
The current is: -0.07
The current charge is: 10.00
The current is: -0.04
The current is: 0.00
The current is: 0.04
The current charge is: 10.01
The current is: 0.07
The current charge is: 10.02
The current charge is: 10.03
The current charge is: 10.04
The current charge is: 10.05
The current charge is: 10.06
The current charge is: 10.07
The current charge is: 10.08
The current charge is: 10.09
The current charge is: 10.10
The current charge is: 10.11
The current charge is: 10.12
The current charge is: 10.13
The current charge is: 10.14
The current charge is: 10.15
The current charge is: 10.16
The current charge is: 10.17
The current is: 0.14
The current charge is: 10.18
The current charge is: 10.20
The current charge is: 10.21
The current charge is: 10.23
The current charge is: 10.24
The current is: 0.18
The current charge is: 10.26
The current is: 0.22
The current charge is: 10.28
The current is: 0.25
The current charge is: 10.31
The current charge is: 10.33
The current is: 0.29
The current charge is: 10.36
The current charge is: 10.38
The current charge is: 10.41
The current charge is: 10.43
The current charge is: 10.46
The current charge is: 10.48
The current charge is: 10.50
The current charge is: 10.52
The current is: 0.11
The current charge is: 10.53
The current charge is: 10.54
The current charge is: 10.55
The current charge is: 10.57
The current charge is: 10.58
The current charge is: 10.60
The current charge is: 10.62
The current charge is: 10.64
The current charge is: 10.66
The current charge is: 10.69
The current is: 0.32
The current charge is: 10.72
The current charge is: 10.75
The current charge is: 10.78
The current charge is: 10.81
The current charge is: 10.84
The current charge is: 10.87
The current charge is: 10.90
The current charge is: 10.93
The current is: 0.36
The current charge is: 10.97
The current charge is: 11.00
The current charge is: 11.04
The current charge is: 11.07
The current charge is: 11.11
The current charge is: 11.15
The current charge is: 11.18
The current charge is: 11.21
The current charge is: 11.24
The current charge is: 11.27
The current charge is: 11.31
The current charge is: 11.34
The current charge is: 11.38
I realize that we are able to set the cursor further down the SD file to be able to read the values but I had very little to no success at doing this with my file being around 60.8MB and every input being sized at 51 bytes.
Here is the code I have been using to test:
SD card read/write
This example shows how to read and write data to and from an SD card file
The circuit:
SD card attached to SPI bus as follows:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 10 (for MKRZero SD: SDCARD_SS_PIN)
created Nov 2010
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
This example code is in the public domain.
#include <SPI.h>
#include <SD.h>
File myFile;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
if (!SD.begin(10)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");
// open the file for reading:
myFile = SD.open("TEST1.CSV");
if (myFile) {
Serial.println("TEST1.CSV");
// read from the file until there's nothing else in it:
while (myFile.available()) {
int fileLength = myFile.available();
int recordCount = fileLength / 51;
int lastRecordStart = (recordCount - 1) * 51;
myFile.seek(lastRecordStart); // Position the read cursor at the start of the last record
Serial.write(myFile.read());
// close the file:
myFile.close();
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
// nothing happens after setup
