Retrieving sensor values from Arduino UNO via PHP GET
Hi! I have tried pretty much everything I could think of, and Google has not been of much help unfortunately…
Basically, I have built an Arduino UNO based Ethernet thermometer and its working GREAT thanks to the valuable help from this community!
Now I’d like to push the project a bit further and monitor the sensor’s output.
As it is now, I can access the ethernet thermometer’s webpage and see the sensor’s readings so I know the Arduino side of the project is working fine. I can also store values to a MySQL database fine via a PHP script so this is also working fine. Its getting the values from the Arduino that is puzzling me. I have tried several php scripts from the internet but none have been working…
My PHP script:
<?php
header('Content-type: text/plain');
$link = mysql_connect("localhost", "username", "password") or die("Cannot login to MySQL server!!: " . mysql_error());
mysql_select_db("arduino") or die("Unable to select DB!!");
$query = "INSERT INTO temp(temp_string_a, temp_string_b, temp_string_c, temp_string_d, temp_string_e) VALUES ('" . $_GET['temp_string_a'] . "', '" . $_GET['temp_string_b'] . "','" . $_GET['temp_string_c'] . "','" . $_GET['temp_string_d'] . "', '" . $_GET['temp_string_e'] . "')";$result = mysql_query($query) or die("Request failed!!: " . mysql_error());
mysql_close($link);
The Arduino sketch (Special Thanks to the devs at code.google.com/p/webduino for their sketch!!!) is attached to this post because the overall length exceeded the forum’s maximum post length
One of the things that worries me (and I think this is pretty normal) is the fact that the PHP code has no mean to retrieve from an ethernet connection… Nowhere I indicated the device’s IP… I am very useless in PHP programming and in C++ in general so please give me a chance… :wink:
Can anyone help me tie the two ends together and successfully retrieve the sensor’s data and store to the MySQL DB?
Thank you!!
arduino_r00.ino (7.04 KB)
