Control a RGB LED with 3 numbers wrote in Serial Monitor (done);
Use a BT received string in format "?,?,?" to control the same RGB LED.
Equipment: UNO + HC-05 BT module + Android Phone with MIT inventor app
Achieved: Serial monitor shows that data sent from mobile is ok and I have a string like 255,0,0.
Questions:
If I do work with the whole string, how can I separate each number and assign to a variable? (presumably substring won´t work because I don´t know the size of each number in advance);
Would be a better approach to use an array of char and use "," as a separator in strtok?
What do you reccomend?
Better coding tips are welcome too
[code]
#include <SoftwareSerial.h>
#define PinoRX 5
#define PinoTX 6
#define baudrate 9600
int pinoR = 11;
int pinoG = 10;
int pinoB = 9;
int redval, greenval, blueval;
String msg;
SoftwareSerial hc05(PinoRX , PinoTX);
pinMode(PinoRX, INPUT);
pinMode(PinoTX, OUTPUT);
pinMode(4, OUTPUT);
pinMode(3, OUTPUT);
digitalWrite(4, HIGH);
digitalWrite(3, LOW);
hc05.begin(baudrate);
pinMode(pinoR, OUTPUT);
pinMode(pinoG, OUTPUT);
pinMode(pinoB, OUTPUT);
Serial.println(F("Insira os valores para R G B no formato XXX,XXX,XXX"));
char data;
msg = "";
while (hc05.available()) {
if ((hc05.available() > 0) && data != '.')
delay(10);
char data = hc05.read();
msg += data;
Serial.println (msg);
while (Serial.available()) {
// look for the next valid integer in the incoming serial stream:
redval = Serial.parseInt();
greenval = Serial.parseInt();
blueval = Serial.parseInt();
analogWrite(pinoR, redval);
analogWrite(pinoG, greenval);
analogWrite(pinoB, blueval);
Serial.print(redval);
Serial.print(",");
Serial.print(greenval);
Serial.print(",");
Serial.println(blueval);
[/code]
See the serial input basics tutorial. Example #5 has code to receive a string and parse the values. The default length of the string in the examples is 32, but that is easily changed.
Forget the "String" class, it will most likely cause problems at some point. The most efficient way to do it is to make a custom "parseInt" function for the software serial:
int parseInt(SoftwareSerial &ss, int default = 0)
int result = default;
while (ss.available())
char cc = ss.peak();
if ((cc >= '0') && (cc <= '9'))
result = (result * 10) + (cc - '0');
ss.read();
else break;
return result;
