retrive XML tags data
I am using arduino nano with esp8266 to connect to my wifi network.
I wanted to access an XML file based on particular id.
I have created a web service on my PC. Using this web service as reference to one method employee details. I need to pass the employee ID as a parameter to that method, that will return an XML file like below.
<employee>
                <empID>1001</empID>
                <emp_name>ramesh.d</emp_name>
                <DOJ>29-12-2009</DOJ>
                <salary>10000</salary>
</employee>
From this XML file I need to store the details into my variables like employeeId, Name, DOJ, Salary.
I am using the following code to do this.
#include <string.h>
#include <SPI.h>;
#include <SoftwareSerial.h>
#define DST_IP "192.168.1.102"
#define DEBUG true
SoftwareSerial esp8266(6, 7);
// Define Constants
// Max string length may have to be adjusted depending on data to be extracted
#define MAX_STRING_LEN  20
// Setup vars
char tagStr[MAX_STRING_LEN] = "";
char dataStr[MAX_STRING_LEN] = "";
char tmpStr[MAX_STRING_LEN] = "";
char endTag[3] = {'<', '/', '\0'};
int len;
// DECLARED VARIABLES HERE FOR GLOBAL USE
char ClbSts[MAX_STRING_LEN] = "\0";
char calDate[MAX_STRING_LEN] = "\0";
char nxtCAL[MAX_STRING_LEN] = "\0";
// Flags to differentiate XML tags from document elements (ie. data)
boolean tagFlag = false;
boolean dataFlag = false;
String emp_ID = "1001";
  esp8266.begin(9600); // your esp's baud rate might be different
  //lcd.begin(20, 4);
  sendData("AT+RST\r\n",5000,DEBUG); // reset module
  sendData("AT+CWMODE=3\r\n",2000,DEBUG); // configure as access point
  sendData("AT+CWLAP\r\n",10000,DEBUG);
  String joinAP = "AT+CWJAP=\"INTRO\",\"123458\"";
  joinAP +="\r\n";
  sendData(joinAP,20000,DEBUG);
      String cmd = "AT+CIPSTART=\"TCP\",\""; //make this command: AT+CPISTART="TCP","192.168.1.102",80
      cmd += DST_IP;
      cmd += "\",80";
      cmd += "\r\n";
      sendData(cmd,8000,DEBUG);
      String method ="GET /employee/emp.asmx/empdetails?empcode=";
      method += emp_ID;
      method +="HTTP/1.1\r\n";
      method += "Host: 192.168.1.102\r\n\r\n";
      String cipSend = "AT+CIPSEND=";
      cipSend +=method.length();
      cipSend +="\r\n";
      sendData(cipSend,2000,DEBUG);
      //Send our http GET request
        sendData(method,30000,DEBUG);
        readTags();
      sendData("AT+CIPCLOSE",5000,DEBUG);
// Process each char from web
void readTags() {
    Serial.println("serialEvent Started");
   // Read a char
      char inChar = esp8266.read();
    Serial.print(".");
   if (inChar == '<') {
      addChar(inChar, tmpStr);
      tagFlag = true;
      dataFlag = false;
   } else if (inChar == '>') {
      if (tagFlag) {
         strncpy(tagStr, tmpStr, strlen(tmpStr)+1);
      // Clear tmp
      clearStr(tmpStr);
      tagFlag = false;
      dataFlag = true;
   } else if (inChar != 10) {
      if (tagFlag) {
         // Add tag char to string
         // Check for </XML> end tag, ignore it
         if ( tagFlag && strcmp(tmpStr, endTag) == 0 ) {
            clearStr(tmpStr);
              tagFlag = false;
            dataFlag = false;
      if (dataFlag) {
         // Add data char to string
         addChar(inChar, dataStr);
   // If a LF, process the line
   if (inChar == 10 ) {
      Serial.print("tagStr: ");
      Serial.println(tagStr);
      Serial.print("dataStr: ");
      Serial.println(dataStr);
      // Find specific tags and print data
      if (matchTag("<empID>")) {
//Serial.println("dataStr Length:");
//Serial.print(strlen(dataStr));
//        Serial.println("NAME: ");
//        Serial.print(dataStr[0]);
strncpy(employeeId,dataStr,20);
ClbSts[21] = '\0';
      if (matchTag("<emp_name>")) {
         //Serial.print("   Flavor Name: ");
         //strncpy(flavor_name,dataStr,strlen(dataStr)+1);
         //Serial.print(flavor_name);
      if (matchTag("<DOJ>")) {
         //Serial.print("   Volume to Mix: ");
         //strncpy(mix_volume,dataStr,strlen(dataStr)+1);
         //Serial.print(mix_volume);
         //Serial.print("   ");
      // Clear all strings
      clearStr(tmpStr);
      clearStr(tagStr);
      clearStr(dataStr);
      // Clear Flags
      tagFlag = false;
      dataFlag = false;
// Other Functions //
// Function to clear a string
void clearStr (char* str) {
   int len = strlen(str);
   for (int c = 0; c < len; c++) {
      str[c] = 0;
//Function to add a char to a string and check its length
void addChar (char ch, char* str) {
   char *tagMsg  = "<TRUNCATED_TAG>";
   char *dataMsg = "-TRUNCATED_DATA-";
   // Check the max size of the string to make sure it doesn't grow too
   // big.  If string is beyond MAX_STRING_LEN assume it is unimportant
   // and replace it with a warning message.
   if (strlen(str) > MAX_STRING_LEN - 2) {
      if (tagFlag) {
         clearStr(tagStr);
         strcpy(tagStr,tagMsg);
      if (dataFlag) {
         clearStr(dataStr);
         strcpy(dataStr,dataMsg);
      // Clear the temp buffer and flags to stop current processing
      clearStr(tmpStr);
      tagFlag = false;
      dataFlag = false;
      // Add char to string
      str[strlen(str)] = ch;
// Function to check the current tag for a specific string
boolean matchTag (char* searchTag) {
   if ( strcmp(tagStr, searchTag) == 0 ) {
      return true;
      return false;
String sendData(String command, const int timeout, boolean debug)
    String response = "";
    esp8266.print(command); // send the read character to the esp8266
    long int time = millis();
    while( (time+timeout) > millis())
      while(esp8266.available())
        // The esp has data so display its output to the serial window
        char c = esp8266.read(); // read the next character.
        response+=c;
    if(debug)
      Serial.print(response);
    return response;
This code responding like
+IPD,192:<?xml version="1.0" encoding="utf-8"?>
OK
OK
Unlink
What I have to do?
how could I read the XML nodes?
Is this code correct?
Suggest me corrections if any.
i am poor in english. If anybody can't understand my question. kindly reply me.
