Retrun 2 value from an array of bytes
Hello, I have an array of bytes called values I need to extract bytes at positions 6 and 7 where it should be saved the temperature info of my sensor how can I do it?
byte temperature(){
  Serial.println("---VV---");
  digitalWrite(DE,HIGH);
  digitalWrite(RE,HIGH);
  delay(20);
  Serial.flush();
  if(mod.write(msgt,sizeof(msgt))==8){
    digitalWrite(DE,LOW);
    digitalWrite(RE,LOW);
    for(byte i=0;i<10;i++){
    values[i] = mod.read();
    Serial.print("|");
    Serial.print(values[i],HEX);
    Serial.println("-----");
    Serial.flush();
    delay(3000);
// I'm try to return the value that should be host at position 6 and 7
  return values[6,7];
for example:
here my values array: |1|3|4|3|E8|1|3F|3B|C3|
it should return 13F
Imho a simple solution would be that you return already a two byte integer, not an array.
int temperature(){
  other stuff
  int result = ((int)value[5] << 8) | value[6];   // shift one  byte and add the other,
  //  int result = ((int)value[6] << 8) | value[5];  // alternative if you need the temperature in the other order
  Serial.println(result, HEX); // just to check if the order of bytes is as you need them
  Serial.println(result);
  return result;
Agree with @noasica.
If you really want to return 2 separate bytes, you can put them in a struct or you can add two byte addresses as parameters to your function.
