Return problem with Serial Prompt function (?)
I'm having odd "Return" problems. Here's the code:
int read;
void setup(){ Serial.begin(9600); prompt("A or B", "0 | A", "1 | B", 0, 1, 0, 1); }
void loop(){
void prompt(String m1,String m2,String m3,int i1,int i2,int o1,int o2){ int a = o1; int b = o2; while(!Serial){} Serial.println(m1); Serial.println(m2); Serial.println(m3); while(!Serial.available()){} int input = Serial.parseInt(); if(input == i1){ return a; }else if(input == i2){ return b; } }
For some reason it's giving an error on return saying:
Arduino: 1.6.5 (Mac OS X), Board: "Arduino Uno"
testytest.ino: In function 'void prompt(String, String, String, int, int, int, int)': testytest:22: error: return-statement with a value, in function returning 'void' [-fpermissive] testytest:24: error: return-statement with a value, in function returning 'void' [-fpermissive] return-statement with a value, in function returning 'void' [-fpermissive]
When you post on the forum use the code tag </>.
The problem is that you declared the prompt function as void, and are trying to return an int.
Change the void prompt, to int prompt, and it should compile.
Arank:
Thank you!
