Return Sintax
Just a quick question. I am developing a project of multiple timers using an RF Robot LCD shield. My question is this;
int ReadButtons()
  ButtonState = analogRead(A0);                //Read the value from the sensor
  delay(5);                                 //Debounce delay
  int k = (analogRead(A0) - ButtonState);      //Gives the button a slight range to allow for a little contact resistance noise
  if (5 < abs(k)) return NoButton;          //Double checks the keypress. If the two readings are not equal +/-k value after debounce delay, it tries again.
  if (ButtonState > 1000) return NoButton;     //No button
  if (ButtonState < 50) return BtnRight;       //Right button
  if (ButtonState < 555) return BtnLeft;       //Left button
  if (ButtonState < 380) return BtnSave;       //Save button
  if (ButtonState < 195) return BtnBack;       //Back button
  return NoButton;                          //Default if no buttons are pressed
The above is a section of my code for the buttons. Note that I use a return then the name of the button. Now in the loop I want call on each button could I write something like this;
if (ButtonState == BtnSave)
do something here
else if
(ButtonState == BtnBack)
do something here
I would greatly help please.
If ButtonState is say 379 or 194 what will be returned ?
if (ReadButtons() == BtnSave)
do something here
else if
(ReadButtons() == BtnBack)
do something here
Or better yet:
int ButtonState = ReadButtons();  // This is a NEW ButtonState Variable, not the same one in the function, just same name
do something here
else if
do something here
Nothing. Those resistances are for the remainder buttons on the shield which I wont be using.
Thanks for the help with the code. Much appreciated.
You logic is broken:
  if (ButtonState > 1000) return NoButton;     //  Works OK
  if (ButtonState < 50) return BtnRight;         //  Works OK
  if (ButtonState < 555) return BtnLeft;         //  Works OK
  if (ButtonState < 380) return BtnSave;       //  Will never be executed, because 380 is also < 555
  if (ButtonState < 195) return BtnBack;       //  Will never be executed, because 195 is also < 380
You must always work either UP through the values IN ORDER, testing for </<=, or DOWN through the values, testing for >/>=.
Regards,
Ray L.
Gotcha. Thanks.
