Hi
does anyone know how to return to a point in the loop. is it possible to have an if true else return to the beginning of the if or an if true skip to a point in the loop.
Any help is appreciated
That's a very broad question and not easy to give a simple answer.
A starting point might be to study "break", and "return" as well as "for" and "while".
I could probably help more if you describe the problem you want to solve.
...R
There exists this - http://www.cplusplus.com/reference/csetjmp/longjmp/ -
but it is considered a bad idea as you can corrupt the internal accounting of the program.
dansam8:
Hi
This sounds like an attempt to create spaghetti code - what are you actually
trying to achieve - perhaps you are needing a continue, a state-machine, exception handling
or something else.
can you give an example of (pseudo) code what you want to do...
If you are looking to do something like this...
while (<some condition>) {
if (myboolean) goto skip;
// do some loop stuff
skip:
// do myboolean stuff
Try this instead...
if (!myboolean)
If you are trying to do something like this...
loop:
if (myboolean)
// do something
goto loop;
Try this instead...
while (!myboolean);
// do something
Both of these of course assume that myboolean will get changed in an ISR somewhere.
dansam8:
Quite simply if you think you want to do this you are not coding correctly.
There will be a way to produce some structured code that does not need this concept.
