int SelectSketchTable(String where, char *rows[]){
String INSERT_ESP12E_SELECT_SQL = "SELECT * FROM SKETCHS WHERE name='" + where + ".bin'";
dbg_printf("%s\n", INSERT_ESP12E_SELECT_SQL.c_str());
MySQL_Cursor *cur_mem = new MySQL_Cursor(&conn);
Connect_to_MySQL();
cur_mem->execute(INSERT_ESP12E_SELECT_SQL.c_str());
column_names *columns = cur_mem->get_columns();
for (int f = 0; f < columns->num_fields; f++) {
Serial.print(columns->fields[f]->name);
if (f < columns->num_fields - 1) {
Serial.print(", ");
dbg_printf("\n");
row_values *row;
int i = 0;
do {
row = cur_mem->get_next_row();
if (row != nullptr) {
//Serial.print(row->values[f]);
rows[i] = row->values[f];
Serial.print(rows[i]);
i++;
Serial.print(", ");
} while (row != nullptr);
cur_mem->close();
delete cur_mem;
Disconnect_to_MySQL();
dbg_printf("select end\n");
return i;
ESP_INFO esp_info;
char *Rows[5];
memset(Rows,0,sizeof(char)*5);
int count = SelectSketchTable(esp_info.sketch_name, Rows);
dbg_printf("SelectSketchTable succeeded.\n");
for(int i = 0; i < count; i++)
dbg_printf("%d -> %s\n", i, Rows[i]);
Results:
SELECT * FROM SKETCHS WHERE name='firmware.bin'
Connecting to MySql.
name, path, md5
firmware.bin, /var/www/html/firmware/ESP-12E/fw.bin, b0f36f5ad0affe3b4336fcaa80ac75c6
select end
0 ->
1 -> '/www/html/firmware/ESP-12E/fw.bin
2 -> �
I can't get values of Rows variable correctly. Values are correct in the function, but they change when they return to the called position. What could be the reason for this.
