Hi there please help me, ive been working on this for a week...
-The circuit will have 3 buttons, one for change mode, one for set the value and another one will count the number of button pushes,
-The circuit will initially start at 25, after change mode button is pushed once, the program will jump to fucntion count
-the initial value will be added with the number of button being pushes
-The set button is push so we can return the new value to the main loop function
-If we push the button mode once more, the program will jump to function count2
-at count2, the function suppose to decrease the value as we set before corresponding to the number of button push being pushes
-eg. (initial Y=25, >>>> set to Y=30 >>>> decrease back to Y=23 from Y=30)
-problem happens after executes function counter,
-once we updated the final value Y, we return to main loop and display the final value on the lCD
-but when we move to counter2, the final value Y is not updated from what we have done before, instead it will decrease from the intial value
-eg. initially Y=25 >>>>>> press buttonmode to HIGH >>>> counter (add value to initial value 25) >>>> (press buttonset to HIGH) set value to Y=30 >>>> press buttonmode to HIGH again>>>> counter2 (should decrease value from Y=30 but Y is not updated and decrease Y from intial 25 instead) >>> (press buttonset to HIGH) set value Y=27 for example)
Thanks! Cheers! XD
mode_button_xjadi.ino (4.46 KB)
