Returning a std::vector from a Function
When you return a std::vector from a function, is the compiler clever enough to use the vector’s Move Constructor and Move Assignment function to transfer ownership of the data to the receiving function?
#include <vector>
using ByteVector = std::vector<uint8_t>;
ByteVector getVector();
  // Get vector of values
  ByteVector values = getVector();
  //  Use values from the vector
  // The vector's lifetime ends here. Dynamic storage space returned to the heap;
ByteVector getVector(){
  ByteVector v;
  // Put values in the vector
  // Return the vector
  return v;
Or must I use std::move() to avoid unnecessary copying?
#include <vector>
ByteVector getVector() {
  ByteVector v;
  return std::move(v);
Same question for a function returning a struct that contains a std::vector:
#include <vector>
struct MyStruct {
  float floatValue;
  ByteVector theVector;
MyStruct getStruct();
  MyStruct values = getStruct();
  //  Use values from the struct
  // The struct's lifetime ends here. Dynamic storage space returned to the heap;
MyStruct getStruct(){
  MyStruct s;
  // Put values in the struct;
  // Return the struct
  return s;
Even better: in many cases, you may not even get a move constructor call, and the returned value is constructed in-place (e.g. in the stack frame of the caller).
See Copy elision - cppreference.com for details.
You should not move the returned value, that may actually result in worse performance. (If you return a struct or a tuple, you may want to move the members into the struct/tuple, though.)
OK, thanks. So for the vector case just:
  return v;
And for the struct case create custom Move operations??
#include <vector>
struct MyStruct {
  float floatValue;
  MyStruct(MyStruct &&other) {
    floatValue = other.floatValue;
    theVector = std::move(theVector);
  MyStruct(MyStruct &other) {
    theVector = theVector;
  MyStruct &operator=(MyStruct &&other) {
    return *this;
  MyStruct &operator=(MyStruct &other) {
    return *this;
  MyStruct() = default;
  ~MyStruct() = default;
No, you don't need custom move operations for the struct.
If you're just returning an instance of your struct, don't move anything.
MyStruct getStruct() {
  MyStruct m;
  return m; // no move
But if you already have a vector and you want to wrap it in a struct before returning, you should move the vector into the struct.
  std::vector v { /* ... */ };
  return {3.14f, std::move(v)}; // move vector into struct
The code's structure may be such that I can populate the vector in situ:
  MyStruct s;
  s.theVector.push_back(0xC1);
  s.theVector.push_back(0xC2);
  s.floatValue = 3.14;
  return s;
