returning a value from a function
i have a problem with returning a value from a function.
i have the main loop and a function for reading my accelerometer and inside the ‘readAccel()’ function i am able to read the values of x, y and z but i want to be able to transfer these values (in the example z is returned) from this loop and use them inside the main loop but it doesnt work as i just read 0 from void loop() and i cant seem to figure out where i am going wrong. Any guidance will be much appreciated.
   readAccel(); // read the x/y/z tilt
  Serial.print(" z: ");
  Serial.println( z );
  delay(10);
 float readAccel() {
  uint8_t howManyBytesToRead = 6;
  readFrom( DATAX0, howManyBytesToRead, _buff); //read the acceleration data from the ADXL345
  // each axis reading comes in 10 bit resolution, ie 2 bytes.  Least Significat Byte first!!
  // thus we are converting both bytes in to one int
  int x = (((int)_buff[1]) << 8) | _buff[0];
  int y = (((int)_buff[3]) << 8) | _buff[2];
  int z = (((int)_buff[5]) << 8) | _buff[4];
  Serial.print("x: ");
  Serial.print( x );
  Serial.print(" y: ");
  Serial.print( y );
  return z;
Make sure braces match.
Make sure return types are the same.
Make sure you post all your code.
this is the proper use for a returned value
  Serial.println( readAccel() );
  delay(10);
z is a local variable to readAccel().
you can either print it directly like above or assign it to another variable
int zz = readAccel();
Serial.println( zz );
mistergreen:
thanks mistergreen, this was the source of my problem and now it works so cheers pal have a nice day :slight_smile:
You don't think that posting incomplete code that had mismatched braces was partly to blame?
Or that returning an int, when the function is supposed to return a float was a contributing factor? Why does the function return a float, anyway?
