Returning an array in function
Hi, So I got this code in which I calculate the intersection of 2 lines, the algorithm works but there is an error I can't solve.
Error:
error: expected unqualified-id before '[' token
Here is the code:
double[] Intersect(double[2] ClineP1, double[2] ClineP2, double[2] OlineP1, double[2] OlineP2)
//the line above is where the error pops up
        //Line1
        double A1 = ClineP2[1] - ClineP1[1];
        double B1 = ClineP2[0] - ClineP1[0];
        double C1 = A1*ClineP1[0] + B1*ClineP1[1];
        //Line2
        double A2 = OlineP2[1] - OlineP1[1];
        double B2 = OlineP2[0] - OlineP1[0];
        double C2 = A2 * OlineP1[0] + B2 * OlineP1[1];
        double delta = A1*B2 - A2*B1;
        if(delta == 0 || ) {
        Serial.println("Lines are parallel");}
else{
        double x = (B2*C1 - B1*C2)/delta;
        double y = (A1*C2 - A2*C1)/delta;
        double[2] xy = {x, y};
        return xy;
Thank you in advance!
You can only return one value from a function. Just one. You cannot return a whole array.
You should make the array global and then there will be no reason to need to return it.
Alternatively you can return a pointer to the array, but be careful that the pointer will still be good when you go to use it.
I knew there is the 'sstream' in c++ that I used before, is there anything similar to that in arduino?
You can return a struct from a function.
You can also do this. http://cpp.sh/3ncd
Before & After: http://cpp.sh/2ecc
Using a struct: http://cpp.sh/6hct
Returning large amounts of data from a function is not a good idea because it puts it on the stack. Better to create a global array and use that.
I have made it a global array and there is still an error that pops up:
Error:
Final:273: error: expected ',' or '...' before 'ClineP1'
Final.ino: In function 'void Intersect(double*)':
Final:276: error: 'ClineP2' was not declared in this scope
Final:276: error: 'ClineP1' was not declared in this scope
Final:277: error: expected unqualified-id before numeric constant
Final:281: error: 'OlineP2' was not declared in this scope
Final:281: error: 'OlineP1' was not declared in this scope
My code :
void Intersect(double[2] ClineP1, double[2] ClineP2, double[2] OlineP1, double[2] OlineP2) //273
        //Line1
        //Line2
        double C2 = (A2 * OlineP1[0]) + (B2 * OlineP1[1]);
        if(delta == 0  ) {
else{
The function arguments should not specify the length of the arrays:
void Intersect(double[] ClineP1, double[] ClineP2, double[] OlineP1, double[] OlineP2)
Of course, it would help a lot if you told us WHAT the error was, not just where it is....
Regards, Ray L.
I tried removing the arguments but the error still pops up and I don't know what the error is.
What's this?
What is your revised code and what is the error? We don't know what the error is either.
Alright, I managed to narrow error down to 1, All i had to do was to remove the [] and put it after the variable.
My code now:
void Intersect(double ClineP1[], double ClineP2[], double OlineP1[], double OlineP2[])
        //Line1
        double B1 = ClineP2[0] - ClineP1[0]; // this line is where the error
        //Line2
        if(delta == 0  ) {
else{
Error: Final:277: error: expected unqualified-id before numeric constant
So I got this code in which I calculate the intersection of 2 lines, the algorithm works ...
So what is the problem if it works?
Is this related to http://forum.arduino.cc/index.php?topic=307012
So this is a slope of two line sand I want to know the heading of each line to know where they intersect.
You chose to ignore reply #9, right?
Why post, if you ignore the answers? May as well get a Ouija board.
a few thoughts
double delta = A1*B2 - A2*B1; if(delta == 0 )
comparing a double to 0 is asking for trouble
in arduino ide 1.62 a double named B1 won't compile
the resulting sign of your intersect point is incorrect when I tried
double l11[] = {0,0}; double l12[] = {3,3}; double l21[] = {0,3}; double l22[] = {3,0};
Intersect( l11,l12,l21,l22);
Which reply?
racpi: a few thoughts
Once I changed the name of B1, the function worked. Thank you!
