Returning bool value from function
I am having some trouble with my buffer code, i am using a adafruit feather m0.
this is my log:
In function 'void seq_send(byte, byte, byte, byte)':
sequencer:92:8: error: void value not ignored as it ought to be
skip = buffer_scan(channel, command, data1, data2);
void seq_send(byte channel, byte command, byte data1, byte data2) {
  bool skip;
  if (skip == 1)
    debug.print("ignored a note");
void buffer_scan(byte channel, byte command, byte data1, byte data2)
  bool result = 0;
  if (seqBuf_size > 0)
    debug.print("seq buffer size: "); debug.println(seqBuf_size);
    for (int b = 1; b >= seqBuf_size; b++)
      if (seqBuf_channel[b] == channel && seqBuf_data1[b] == data1 && seqBuf_data2[b] == data2)
        result = 1;
        debug.print("found match in buffer"); debug.print(seqBuf_channel[b]); debug.print(seqBuf_data1[b]); debug.print(seqBuf_data2[b]);
        debug.println("");
  return result;
"void" means "this function doesn't return anything."
If you want to return a boolean then declare the buffer_scan function as boolean.
Okey thanks, will it still accept three byte inputs?
brorgustav:
If that's how you write the definition. That has nothing to do with the return type.
boolean allEqual(byte a, byte b, byte c){
   if (a == b && a == c) return true;
   return false;
Thanks for the answers
