Returning char arrays to a function
Hello everyone,
I’m trying to make a Rubux cube solver (using the CFOP method to solve the cube) and I have a question about my code (it is not finished yet):
So far I have made multiple sketches of which one head sketch. This is the code of that sketch:
#include <Stepper.h>
#define W_DIR_PIN             1
#define W_STEP_PIN            2
#define G_DIR_PIN             3
#define G_STEP_PIN            4
#define R_DIR_PIN             5
#define R_STEP_PIN            6
#define B_DIR_PIN             7
#define B_STEP_PIN            8
#define O_DIR_PIN             9
#define O_STEP_PIN            10
#define Y_DIR_PIN             11
#define Y_STEP_PIN            12
  pinMode(W_DIR_PIN,        OUTPUT);
  pinMode(W_STEP_PIN,       OUTPUT);
  pinMode(G_DIR_PIN,        OUTPUT);
  pinMode(G_STEP_PIN,       OUTPUT);
  pinMode(R_DIR_PIN,        OUTPUT);
  pinMode(R_STEP_PIN,       OUTPUT);
  pinMode(B_DIR_PIN,        OUTPUT);
  pinMode(B_STEP_PIN,       OUTPUT);
  pinMode(O_DIR_PIN,        OUTPUT);
  pinMode(O_STEP_PIN,       OUTPUT);
  pinMode(Y_DIR_PIN,        OUTPUT);
  pinMode(Y_STEP_PIN,       OUTPUT);
  char White[9];
  char Blue[9];
  char Orange[9];
  char Green[9];
  char Red[9];
  char Yellow[9];
  Input(White, Blue, Orange, Green, Red, Yellow);
  OLL(Yellow, Blue, Orange, Green, Red);
  PLL(Blue, Orange, Green, Red);
  Turns(URotationsPLL, RotationsPLL);
In another sketch, I programmed the code for the function PLL:
void PLL(char Blue[], char Orange[], char Green[], char Red[]) {
  for (int i = 0; i <= 3; i++){
    switch (i) {
      case 0: char URotationsPLL[1] = {}; break;
      case 1: URotationsPLL[2] = {'U'}; break;
      case 2: URotationsPLL[2] = {"U2"}; break;
      case 3: URotationsPLL[2] = {"Uc"}; break;
    if ((Blue[6] == Blue[7] == Red[2]) && (Orange[6] == Red[0])) {
      char RotationsPLL[10][3] = {"Rc", "B", "Rc", "G2", "R", "Bc", "Rc", "G2", "R2"};
      i = 4;
    } //PLL Aa (Code of the PLL case)
    else if ((Blue[6] == Blue[7] == Green[4]) && (Orange[5] == Red[1] == Blue[0])) {
      char RotationsPLL[10][3] = {"R2", "G2", "R", "B", "Rc", "G2", "R", "Bc", "R"};
      i = 4;
    } //PLL Ab
    // 19 more cases (are pretty much the same as the ones above; just a slightly different if statement and array)
    else {
      Blue[0] = Extra[9];
      Blue[7] = Extra[10];
      Blue[6] = Extra[11];
      Orange[6] = Extra[0];
      Orange[5] = Extra[1];
      Orange[4] = Extra[2];
      Green[4] = Extra[3];
      Green[3] = Extra[4];
      Green[2] = Extra[5];
      Red[2] = Extra[6];
      Red[1] = Extra[7];
      Red[0] = Extra[8];
The letters between the braces (such as {‘U’}) represents the turn the robot needs to do to solve that part of the Cube.
My first question is: I am allowed to compare those arrays (e.g. Blue[6] == Blue[7] == Red[2]) in this way?
Further on, my problem is I need to process those turns (the codes in URotationsPLL and RotationsPLL) in another sketch (the function Turns, which has not been programmed yet). And to do that, I need to be able to use those variables in that sketch.
I thought it might be possible to combine URotationsPLL and RotationsPLL to one array and return that combined array to the function or to return multiple arrays to one function, but I have no idea if either one of those ideas are possible.
So is it possible or is there a better, easier solution?
Thank you in advance,
timozzzz
This is my first big project with Arduino, so there probably will be mistakes in the code
You are actually attempting to compare array elements, not entire arrays.
It's clear what you are trying to do, but I guess you have got to do it like this:
if ( Blue[6] == Blue[7] && Blue[7] == Red[2] ) {
// action here
The == is a binary operator, which means it takes two operands.
So, I'm pretty certain that your a == b == c is interpreted as (a == b) == c. So, you are comparing c to the boolean result of a == b, which works in C++, but is not what you want.
The example given by 6v6gt is the correct way to do what you intend.
timozzzz:
  for (int i = 0; i <= 3; i++) {
    switch (i) {
void setup() {}
void loop() {}
generates a lot of serious warnings.
Somewhere\PLL\PLL.ino: In function 'void PLL(char*, char*, char*, char*)':
Somewhere\PLL\PLL.ino:5:12: warning: jump to case label [-fpermissive]
Somewhere\PLL\PLL.ino:4:20: note:   crosses initialization of 'char URotationsPLL [1]'
Somewhere\PLL\PLL.ino:6:12: warning: jump to case label [-fpermissive]
Somewhere\PLL\PLL.ino:6:32: warning: invalid conversion from 'const char*' to 'char' [-fpermissive]
Somewhere\PLL\PLL.ino:7:12: warning: jump to case label [-fpermissive]
Somewhere\PLL\PLL.ino:7:32: warning: invalid conversion from 'const char*' to 'char' [-fpermissive]
First of all, thank you all for your responses
So far I changed the code like 6v6gt suggested. Also I replaced the switch statements in if statements. All of the warnings are gone right now.
if (i == 0) {
  char URotationsPLL[] = {};
else if (i == 1) {
  char URotationsPLL[] = {'U'};
else if (i == 2) {
  char URotationsPLL[] = {"U2"};
else if (i == 3) {
  char URotationsPLL[] = {"Uc"};
Does anyone know how I can solve the other problem?
timozzzz:
if (i == 0) {
char URotationsPLL = {};
   else if (i == 1) {
     char URotationsPLL = {'U'};
   else if (i == 2) {
     char URotationsPLL = {"U2"};
   else if (i == 3) {
     char URotationsPLL = {"Uc"};
That code is nonsense, hast no effect and will probably be removed by the compiler.
And I get warnings for that code.
Somewhere\PLL\PLL.ino:4:12: warning: unused variable 'URotationsPLL' [-Wunused-variable]
Somewhere\PLL\PLL.ino:7:12: warning: unused variable 'URotationsPLL' [-Wunused-variable]
Somewhere\PLL\PLL.ino:10:12: warning: unused variable 'URotationsPLL' [-Wunused-variable]
Somewhere\PLL\PLL.ino:13:12: warning: unused variable 'URotationsPLL' [-Wunused-variable]
I am going to use those variables somewhere else (not in this sketch). I think that will remove those warnings, beceause they are used then
timozzzz:
No.
You can not use variables outside the defining block.
char URotationsPLL[] = "unexpected";
    if (i == 0) {
    else if (i == 1) {
    else if (i == 2) {
    else if (i == 3) {
  Serial.print(F("URotationsPLL[] = '"));
  Serial.print(URotationsPLL);
  Serial.println('\'');
char blue[] = "blue";
char orange[] = "orange";
char green[] = "green";
char red[] = "red";
  Serial.begin(250000);
  PLL(blue, orange, green, red);
void loop() {}
URotationsPLL[] = 'unexpected'
