Returning Max Data
Hello,
I am working on a Science Fair Project about how the strength of 3D-printed plastic is correlated to its extrusion temperature, and I am attempting to use a force sensitive resistor to measure the force applied until the plastic breaks. I have been testing out some code before I began the actual experimentation but am still struggling on how to narrow down the amount of data I am receiving. I am hoping to have the board (Uno) return values only if they are larger than previous ones. Attached is the code I currently have.
Thank you!
int force;
int forceprev;
int Pressurepin = A0;
    force = analogRead(Pressurepin);
    forceprev != analogRead(Pressurepin);
    if (force > forceprev)
       Serial.println(force);
       else{}
    delay(100);
FSRFinal.zip (2.38 KB)
The second line of this does not make sense
I'm not even sure what you think it might do
Try something simple and obvious like this
    forceprev = force;
    // etc
...R
Thanks for your help!
The second line came from when I was looking at a debouncing reference from the Chrono library. I think it helped to eliminate all the unnecessary zeros I got from the serial monitor. I did not know exactly what it would do.
When I switched out my bad lines lines for the ones you provided me with the program worked, and it eliminated most of the lesser values. I will test it again in the experiment soon.
Thank you again!
Does nothing useful, but it does waste around 100 microseconds.
Thanks! I was beginning to wonder if it actually did anything.
