Another newbie to the crowd and fired up my first 'ino with the blink-test; woot!
So here's the fun question: I would like to start coding for later deployment of sensors (ph, temp, etc) however I do not actually have the sensors yet. I'm wondering if I could code the Arduino to simply spit out a null value (or preset value) if the code is good.
Ideally I would like to use 0 as an error value (ie: no input received, blah blah) and a preset value as a confirmation that all is well (which would later be replaced by the true sensor value).
Thoughts?
And no, I don't have an existing code to link up... yet.
Maybe. All you can emulate is reading the sensor. Getting a value from the sensor, and pretending to have gotten a value from the sensor, have little to do with whether the code that deals with that value is any good, though.
At a later date, will replace that code-bit with sampling the true values from the sensors. Perfect; I can get on with coding the rest of the project. Merci beaucoup!
