returns position of files problem?
file.position() returns the file starting position?
why the gap is 32 every file position?
and the TEST.TXT’s position is not 128(which is 96+32)
the position become so big.
Why The root.position and Last value is different in the image?
#include <SD.h>
File myFile,root;
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.print("Initializing SD card...");
  // On the Ethernet Shield, CS is pin 4. It's set as an output by default.
  // Note that even if it's not used as the CS pin, the hardware SS pin
  // (10 on most Arduino boards, 53 on the Mega) must be left as an output
  // or the SD library functions will not work.
  pinMode(10, OUTPUT);
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  // open a new file and immediately close it:
  Serial.println("Creating 2222.txt...");
  myFile = SD.open("2222.txt", FILE_WRITE);
  delay(1500);
  Serial.print("create.position:  ");
  Serial.println(myFile.position());
  myFile.close();
  Serial.println("Delay");
  delay(3000);
  root = SD.open("/");
  Serial.print("root.position:  ");
  Serial.println(root.position());
  printDirectory(root, 0);
  Serial.println("Removing 2222.txt...");
  SD.remove("2222.txt");
  // nothing happens after setup finishes.
void printDirectory(File dir, int numTabs) {
 Serial.print("FIRST:  ");
 Serial.println(dir.position());
 dir.seek(0);
 Serial.print("Seek");
 Serial.print("dir.size");
 Serial.println(dir.size());
   while(true) {
     File entry =  dir.openNextFile();
     if (! entry) {
       // no more files
     for (uint8_t i=0; i<numTabs; i++) {
       Serial.print('\t');
     Serial.print(entry.name());
     if (entry.isDirectory()) {
       Serial.println("/");
       printDirectory(entry, numTabs+1);
       // files have sizes, directories do not
       Serial.print("\t\t");
       Serial.println(entry.size(), DEC);
       Serial.print("Position:  ");
     entry.close();
   Serial.print("LAST:  ");
the image http://ppt.cc/6KmbZ
AKAI:
the image: http://ppt.cc/6KmbZ
#include <SD.h>
File myFile,root;
  while (!Serial) {
Serial.print(“Initializing SD card…”);
  // On the Ethernet Shield, CS is pin 4. It’s set as an output by default.
  // Note that even if it’s not used as the CS pin, the hardware SS pin
if (!SD.begin(4)) {
    Serial.println(“initialization failed!”);
    return;
  Serial.println(“initialization done.”);
  Serial.println(“Creating 2222.txt…”);
  myFile = SD.open(“2222.txt”, FILE_WRITE);
  delay(1500);
  Serial.print(“create.position:  “);
  myFile.close();
  Serial.println(“Delay”);
  delay(3000);
  root = SD.open(”/”);
Serial.println(“Removing 2222.txt…”);
  SD.remove(“2222.txt”);
dir.seek(0);
Serial.print(“Seek”);
Serial.print(“dir.size”);
  while(true) {
    if (! entry) {
      // no more files
      Serial.print(’\t’);
    entry.close();
