Rev 2 Blynk error
I’m having problems with the Blynk sketch for my Uno Wifi board.
I’ve attached both the code that came with the Blynk library.
And the error code I’m receiving when trying to verify/compile
error1.txt (1.9 KB)
error.txt (40.4 KB)
Code (error1.txt) in code tags:
 Download latest Blynk library here:
   https://github.com/blynkkk/blynk-library/releases/latest
 Blynk is a platform with iOS and Android apps to control
 Arduino, Raspberry Pi and the likes over the Internet.
 You can easily build graphic interfaces for all your
 projects by simply dragging and dropping widgets.
   Downloads, docs, tutorials: http://www.blynk.cc
   Sketch generator:           http://examples.blynk.cc
   Blynk community:            http://community.blynk.cc
   Follow us:                  http://www.fb.com/blynkapp
                               http://twitter.com/blynk_app
 Blynk library is licensed under MIT license
 This example code is in public domain.
 This example shows how to use Arduino.org UNO WiFi
 to connect your project to Blynk.
 Note: This requires WiFi Link library
   from http://librarymanager/all#WiFi_Link
 Please update your UNO WiFi firmware to WiFiLink 1.0.0 (at least).
 Feel free to apply it to any other example. It's simple!
/* Comment this out to disable prints and save space */
#define BLYNK_PRINT Serial
#include <WiFiLink.h>
#include <BlynkSimpleWiFiLink.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "r-25-gZlzoYe0hl1AXpykDbm9YPE3K0l";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "Home Wifi";
char pass[] = "ZeldaDaphne1";
 // Debug console
 Blynk.begin(auth, ssid, pass);
 // You can also specify server:
 //Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 80);
 //Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8080);
 Blynk.run();
