I have recently made a model V8 ic engine and would like to build an arduino based rev counter. Pick up would be from a Hall effect transducer. But would like help with 1) the sketch and 2) how to connect to a suitable digital display.
You also need to know if the Hall Effect transducer is outputting pulses of 0-12V. You will need to step the voltage down to 0-5V for Arduino to read. Sensing a Hall Effect switch is as easy as sensing a button (the arduino actually can't even tell if it's a button or a Hall Effect switch). Get use some details of the sensor and what display you want to use like johnwasser requested.
My input to the arduino was analog, but it seems like the CNY-75B would be generally useful for I or O. It's just a small chip that acts as a transistor but with the gate at a different voltage to the collector and emitter.
You can download a sketch for the rpm counter using a neat little timer library someone made public, and the temperature controlled fan is in C++ using FreeRTOS (not the recently posted DuinOS, and caution - I ran out of memory using it!).
