reverse current protection
Hi everybody,
I've bought this motor shield from pololu:
At page 21 we found:
Reverse battery protection
3 possible solution: (that means one or all??)
  1. A Schottky diode D connected to Vcc pin
    2.A N-channel MOSFET connected to GND pin (see Figure 33: Typical application
    circuit for DC to 10 kHz PWM operation short circuit protection
  2. a P-channel MOSFET connesso al VCC pin
Inoltre, a series resistor must be inserted to limit the current sunk from the microcontroller I/Os. If IRmax is the maximum target reverse current through μC I/Os, the series resistor is:
R = (VIOs - VCC)/ (IRmax)
Somebody could please explain me how proceed?
I use Arduino uno through USB giving 3,3v to an IMU and 5v to the motor shield; with the two GND in common. For the motors I use a lypo battery 7,4v 2000mah.
Additionally, I'm not able to understand how to use enable pin, that have to be set HIGH. Can I put them on the 5v?
Thank you all for the advices
NXTF
Only one of those methods is needed.
What is an IMU?
Yes you can put the enable pin high or you could apply PWM on it to control the motor speed and or turn the motors on and off for a freewheeling stop.
What is an IMU
Admittedly the OP has not given a project objective or overview so we really don't know what he is building but the presence of motors suggests motion so I am going with :
IMU
Sparkfun IMU
raschemmel:
IMU
Sparkfun IMU
YASBR :slight_smile: :slight_smile: another balancing robot
I need a MPU6050 (inertial measurement unit) and a motor driver to control two motors.
Do some Googling to see what IMU unit others have found to work best for
YET ANOTHER SILLY BALANCING ROBOT
In attachment you can find the page of the datasheet I'm not able to understand at all. Could somebody help me?
this is the page where you can download the datasheet
I honestly don't believe you have any idea what they are talking about when they say "Short Circuit Protection" ( I believe they are referring to "Shoot-Through Prevention")
Do you know what "Shoot-Through" is ?
There are several ways to prevent it. One of them is tying the gates of the high side devices to the low side device on the same side. What does that accomplish ? If we ignore the "Master Enable" mosfet at the bottom (that has the diode backwards) , then the schamatic (diagram) you posted shows an H-bridge with 4 mosfets but two inputs (A & B), in addition to the ENA & ENB , plus a PWM input. By tying the HS gates to the LS gates , it is impossible for both the HS device and the LS device to be on at the same time because a TTL HIGH on either input turns OFF the HS device and turns ON the LS device, thereby preventing "Shoot=Through" (the short circuit they are referring to)
The original post said:-
Reverse battery protection is NOT short circuit protection - they are two different things.
The MOSFET at the bottom of that circuit allows current to flow providing the battery is connected the right way round because that way the FET is biased so that it turns on. If the battery is not connected the right way round then that FET will not switch on and so the bridge circuit will not be damaged.
That would be true if it was an N-channel mosfet but look at the source and the drain. If it was an N-channel the current flows from drain to source to ground , not the other way around. The above cstatement would be true for an N-channel at the bottom or a P-channel at the top. This is neither,and the diode is facing the wrong direction.
That's a P-channel mosfet with the arrow is going the wrong way on the gate,(for a P-channel it should go away from the gate. For an N-channel it should be going toward the gate). Either way it doesn't match the symbol for an N channel or P channel. Note the location of the source and drain.
If it's a P-channel it should be at the top between the upper Vcc and lower Vcc in the center. It is in the correct location
But it is, not only is the symbol for an N-channel FET but it even says next to it N MOSFET.
However I take your point on the source and drain connection.
The blocking capacitor I think is the problem here. It would be much simpler to have four diodes catching the back EMF from the coils.
I think what I was really trying to say is that it is upside down.
Somebode seriously stuffed up there.
N-channel fet and zener drawn upside down.
P-channel with -10volt supplied by the IC and not able to be turned off because of the diode.
Option 1 is the most logical one.
Leo..
The OP's post is a request for Reverse battery protection methods.
1-As we all know, the best reverse battery protection, is PAY ATTENTION when connecting the battery !(duh)
2-The second most popular is polarized battery connector which PREVENTS connecting it backwards because it will only plug in one way. (all RC enthusiasts use this method for their Lipo batteries).
3-Then there is Schottky diode connected from Vcc to Ground with the cathode at the Vcc end.
4- A 1N4007 in series with the battery connector at the circuit end with the anode toward the battery connector and the cathode toward the circuit is pretty much fool proof but is unpopular due to the 0.7V drop across the diode. If the battery is feeding the ext. dc barreljack and is more than enough voltage then is a perfect solution.
