How can I reverse HEX data Exp {35 45 6D} to {6D 45 35}? Thank you
You could start by posting your code and a fuller description of the problem.
Briefly, copy from source array while incrementing index and store in destn array while decrementing index.
Adipong_Saengsuk:
dougp:
byte srcArray[] = {0x35, 0x45, 0x6D};
byte dstArray[3];
for(int srcIndex = 2, dstIndex = 0; srcIndex>=0, dstIndex<=2; srcIndex--, dstIndex++)
dstArray[dstIndex] = srcArray[srcIndex];
Serial.print(dstArray[dstIndex], HEX);
Serial.print(" ");
byte temp;
temp = data[2];
data[2] = data[0];
data[0] = temp;
Or something more generic that will work with any size array:
for (byte i = 0; i < (arraysize / 2); i++) {
temp = test[i];
test[i] = test[(arraysize - 1) - i];
test[(arraysize - 1) - i] = temp;
// Example of inverting elements in an array
int test[25];
int temp;
byte arraysize = sizeof(test) / sizeof(test[0]);
for (byte i = 0; i < arraysize; i++) { //fill array with sequential numbers
test[i] = i;
for (byte i = 0; i < arraysize; i++) { //print array contents
Serial.print("Test[");
Serial.print(i);
Serial.print("]=");
Serial.println(test[i]);
delay(5000);
Serial.print("swapping elements ");
Serial.print(i); Serial.print(" <> ");
Serial.println(arraysize - 1 - i);
temp = test[i];
Serial.println("");
Serial.print(i);
Serial.print("]=");
delay(30000);
