Here is what I am trying to do :
- Press the "one" button on the IR remote and have it turn a motor for a period of time and then stop.
- Press the "one" button again on the IR remote and have it turn the motor (reverse) for a period of time and stop.
The code I have below works - Pressing "one" on the IR remote moves the motor and stops. Now I need to add a count (or change state) so it will preform the second part/second press. Right now I can press the "two" button to reverse the motor.
In the future there could be a 3rd and 4th stage to the "one" button and will want to replicate these same functions for other buttons on the IR remote.
TIA
#include <IRremote.h>
#define One_button 0xFF30CF // code received from one button
#define Two_button 0xFF18E7 // code received from two button
#define Three_button 0xFF7A85 // code received from three button
#define Four_button 0xFF10EF // code received from four button
#define Five_button 0xFF38C7 // code received from five button
#define Six_button 0xFF5AA5 // code received from six button
#define Seven_button 0xFF42BD // code received from seven button
#define Eight_button 0xFF4AB5 // code received from eight button
#define Nine_button 0xFF52AD // code received from nine button
#define code1 0xFF7A85 // code received from button no. 3
#define code2 0xFF5AA5 // code received from button no. 6
#define code3 0xFF52AD // code received from button no. 9
// Define sensor pin
int RECV_PIN = 2; //output pin of IR receiver to pin 2 of arduino
//initializing the pins for motors
int rear_elevation_motor1 = 11; //pin 11 of arduino to pin 10 of L293D
int rear_elevation_motor2 = 12; //pin 12 of arduino to pin 15 of L293D
int rear_rotate_motor1 = 6; //pin 6 of arduino to pin 2 of L293D
int rear_rotate_motor2 = 5; //pin 5 of arduino to pin 7 of L293D
//int front_elevation_motor1 = ; //pin 6 of arduino to pin 2 of L293D
//int front_elevation_motor2 = ; //pin 5 of arduino to pin 7 of L293D
//int front_rotate_motor1 = ; //pin 6 of arduino to pin 10 of L293D
//int front_rotate_motor2 = ; //pin 6 of arduino to pin 15 of L293D
// Define IR Receiver and Results Objects
IRrecv irrecv(RECV_PIN); //Arduino will take output of IR receiver from pin 2
decode_results output;
unsigned long currentTime;
int onTime = 5250;
int onTime2 = 4200;
// Serial Monitor @ 9600 baud
// Enable the IR Receiver
irrecv.enableIRIn();
//initializing all the pins where we have connected the motors as output pins
pinMode(rear_elevation_motor1, OUTPUT);
pinMode(rear_elevation_motor2, OUTPUT);
if (irrecv.decode(&output)) {
unsigned long value = output.value;
switch (value) {
case One_button:
digitalWrite(rear_rotate_motor1, LOW);
digitalWrite(rear_rotate_motor2, HIGH);
currentTime = millis();
irrecv.resume();
if ((millis() - currentTime) >= onTime)
digitalWrite(rear_rotate_motor2, LOW);
switch (value) {
case Two_button:
digitalWrite(rear_rotate_motor1, HIGH);
irrecv.resume();
{ if (irrecv.decode(&output)) {
switch (value) {
case Seven_button:
digitalWrite(rear_elevation_motor1, HIGH);
digitalWrite(rear_elevation_motor2, LOW);
irrecv.resume();
if ((millis() - currentTime) >= onTime2)
digitalWrite(rear_elevation_motor1, LOW);
