Reverse Operation (HELP)
Hi to anyone who reads this,
I'm currently doing a project and currently stuck. I'm using UNO Arduino, Easydriver stepper motor and a stepper motor.
I've managed to program and tested included wiring.
My current issue is it can foward and reverse even when i place the alt switch in series with the motor.
But however when i want to reverse, i want it to reverse when i press a button/key thus never foward anymore till i switch back.
Can anyone please advise on how to solve the problem??
My current wiring is as follows
A1 to switch N/C
B1 to switch N/O
You need to provide more detail if you want an accurate answer, but here's a shot.
Psuedo code:
LOOP:
Go direction
Check if front bumper hit
If hit, reverse direction
Check if back bumper hit
If hit, forward direction
END LOOP
With this, you'd basically just need a variable called "Direction," which is only changed if the switch is hit. If the switch is not hit, the bot will continue in "Direction."
be sure to debounce that switch, or at least allow change of directions only once per (estimate) 25 millisecs.
Hi, rogue_wraith,
Thanks for getting back to me. Can you elaborate more on the code as I’ve never used this code before.
This is my current code:
#define DIR_PIN 2
#define STEP_PIN 3
pinMode(DIR_PIN, OUTPUT);
pinMode(STEP_PIN, OUTPUT);
void loop(){
//rotate a specific number of microsteps (8 microsteps per step)
//a 200 step stepper would take 1600 micro steps for one full revolution
rotate(3200, .5);
rotate(-3200, .5); //reverse
void rotate(int steps, float speed){
//rotate a specific number of microsteps (8 microsteps per step) - (negitive for reverse movement)
//speed is any number from .01 → 1 with 1 being fastest - Slower is stronger
int dir = (steps > 0)? HIGH:LOW;
steps = abs(steps);
digitalWrite(DIR_PIN,dir);
float usDelay = (1/speed) * 70;
for(int i=0; i < steps; i++){
digitalWrite(STEP_PIN, HIGH);
delayMicroseconds(usDelay);
digitalWrite(STEP_PIN, LOW);
void rotateDeg(float deg, float speed){
//rotate a specific number of degrees (negitive for reverse movement)
int dir = (deg > 0)? HIGH:LOW;
int steps = abs(deg)*(1/0.225);
Pls can you advise on how to add your code in?
Thanks Again
Btw ,my man from Netherlands thank you as well
i can’t figure out its hardware or software prob.
