Reverse Optoisolator
I want to count the frequency of a voltage higher than 5v
most optoislators take a small voltage and allow you to switch a higher one
i want to use it the other way round switch a high voltage down to a smaller one
voltage will be around 55v max
the frequency could be up to 50 khz
can anyone recommend a suitable component
(a bit like a high voltage level shifter)
Like a transistor that you put small current on the gate (55V through a Big resistance) to switch 5V between emitter and collector?
yes - so the big voltage is switching the digital pin (3.3 v)
No they don't.
They allow a signal that can light an LED to allow an isolated transistor to turn on and off.
If you want the opto isolator to trigger off a large voltage just put a bigger current limiting resistor in series with the signal.
Check the data sheet, not all optical isolators will go that fast.
No. It switches a transistor that allows VCC to flow to or from a pin. The transistor should be a BJT.
If you use an opto-isolator, you will have to check is parameters to see if it will work at 50kHz.
What is the application?
Tom.... :slight_smile:
looks like a zero point crossing chip is the way to go
however i need to try one as the signal may not go negative
https://uk.rs-online.com/web/p/solid-state-relays/8113264/
No that is not the way to count a frequency.
Is this an X/Y Problem ?
Are you are really looking frequency counter circuit ?
this will work also
74HC4050
yes a frequency counter at max 30v would do the job
Gadgeroonie:
this will work also
74HC4050
Don't be silly that is just a level shifting chip. Max input voltage 15V.
i think it will work with a Zener and a resistor
Two resistors can convert any high voltage to a lower voltage. Google "voltage divider".
You would use an opto when it is necessary to isolate the ground. For example, connecting your Arduino to a power outlet. You don't want either Active or Neutral connected to the Arduino ground.
Gadgeroonie:
Gadgeroonie:
That 25v spread is still within range of just using a 10 to 1 voltage divider circuit. 3-5.5 volts into a digital pin would be considered high (for a 5volt Arduino)
Is it possible that this is an AC signal? It goes from +55 to -55?
Then you need a level shifter or maybe the zero-crossing detector is appropriate.
The waveform is typically square wave but could be sinewave
The amplitude is typically 12v but you may see spikes from time to time
A motor is controlled based on the frequency of the signal
What is the source of the signal?
Just answering those two questions will help quite a bit.
Gadgeroonie:
So maybe filter the signal and THEN feed it to an isolator since you don't want Arduino to share ground with the AC?
I played with piezos as input devices for a while, they're about all spike when hit. I put the leads through 2 diodes and 1 BJT that filled the jumper between emitter and digital pin and even hitting the disc with a screwdriver handle hard (the table bounced) didn't zap the pin. Diodes can flatten spikes a bit.
