Hi Guys,
I am a complete newbie to this and I think I may have bitten off more than I can chew. I am a aging diy hobby tinkerer and have been put onto Arduino by a friend. My programming skills are very rusty and I am not getting anywhere fast. Any help would be greatly appreciated.
I am trying to design an auto controller for my ro system. It has a pump and three solenoids that control water flow. I need the system to be on for four hours and then off for four over a twenty four hour period. I also need to flush the system with one of the solenoids for one minute every hour. I have compiled a program that does not seem to do the job. The timings are not right on the relays as I was using seconds to show it working over time. Please could anyone help me sort this program out?
#include <Wire.h>
#include "ds3231.h"
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 10, 9, 8, 7);
/* Basic 4 Realy board connection with clock and 1602 display, to control a water RO system with pump and three solenoids.
Each relay is turned on, then relay 1 is switched off after 1 minute. Relay one is then switched on again every hour for 1 minute.
All four relays are then switched off for 4 hours and then the cycle repeats.
There is a real time clock on a 1602 display that can also display time to next flush (relay 1)
You will also see the corresponding Red LED on the 4 Relay board
light up when the relay is on.
define names for the 4 Digital pins On the Arduino
These data pins link to 4 Relay board pins IN1, IN2, IN3,IN4
#define RELAY1 3
#define RELAY2 4
#define RELAY3 5
#define RELAY4 6
#define BUFF_MAX 128
uint8_t time[8];
char recv[BUFF_MAX];
unsigned int recv_size = 0;
unsigned long prev, interval = 1000;
Wire.begin();
DS3231_init(DS3231_INTCN);
memset(recv, 0, BUFF_MAX);
Serial.println("GET time");
lcd.begin(16, 2);
lcd.clear();
//Serial.println("Setting time");
//parse_cmd("T302911604102014", 16);
// Initialise the Arduino data pins for OUTPUT
pinMode(RELAY1, OUTPUT);
pinMode(RELAY2, OUTPUT);
pinMode(RELAY3, OUTPUT);
pinMode(RELAY4, OUTPUT);
char in;
char tempF[6];
float temperature;
char buff[BUFF_MAX];
unsigned long now = millis();
struct ts t;
// show time once in a while
if ((now - prev > interval) && (Serial.available() <= 0)) {
DS3231_get(&t); //Get time
parse_cmd("C", 1);
temperature = DS3231_get_treg(); //Get temperature
dtostrf(temperature, 5, 1, tempF);
lcd.clear();
lcd.setCursor(1, 0);
lcd.print(t.mday);
printMonth(t.mon);
lcd.print(t.year);
lcd.setCursor(0, 1); //Go to second line of the LCD Screen
lcd.print(t.hour);
lcd.print(":");
if (t.min < 10)
lcd.print("0");
lcd.print(t.min);
lcd.print(":");
if (t.sec < 10)
lcd.print("0");
lcd.print(t.sec);
lcd.print(' ');
lcd.print(tempF);
lcd.print((char)223);
lcd.print("C ");
prev = now;
if (Serial.available() > 0) {
in = Serial.read();
if ((in == 10 || in == 13) && (recv_size > 0)) {
parse_cmd(recv, recv_size);
recv_size = 0;
recv[0] = 0;
} else if (in < 48 || in > 122) {
; // ignore ~[0-9A-Za-z]
} else if (recv_size > BUFF_MAX - 2) { // drop lines that are too long
// drop
recv_size = 0;
recv[0] = 0;
} else if (recv_size < BUFF_MAX - 2) {
recv[recv_size] = in;
recv[recv_size + 1] = 0;
recv_size += 1;
void parse_cmd(char *cmd, int cmdsize)
uint8_t i;
uint8_t reg_val;
struct ts t;
//snprintf(buff, BUFF_MAX, "cmd was '%s' %d\n", cmd, cmdsize);
//Serial.print(buff);
// TssmmhhWDDMMYYYY aka set time
if (cmd[0] == 84 && cmdsize == 16) {
//T355720619112011
t.sec = inp2toi(cmd, 1);
t.min = inp2toi(cmd, 3);
t.hour = inp2toi(cmd, 5);
t.wday = inp2toi(cmd, 7);
t.mday = inp2toi(cmd, 8);
t.mon = inp2toi(cmd, 10);
t.year = inp2toi(cmd, 12) * 100 + inp2toi(cmd, 14);
DS3231_set(t);
Serial.println("OK");
} else if (cmd[0] == 49 && cmdsize == 1) { // "1" get alarm 1
DS3231_get_a1(&buff[0], 59);
Serial.println(buff);
} else if (cmd[0] == 50 && cmdsize == 1) { // "2" get alarm 1
DS3231_get_a2(&buff[0], 59);
} else if (cmd[0] == 51 && cmdsize == 1) { // "3" get aging register
Serial.print("aging reg is ");
Serial.println(DS3231_get_aging(), DEC);
} else if (cmd[0] == 65 && cmdsize == 9) { // "A" set alarm 1
DS3231_set_creg(DS3231_INTCN | DS3231_A1IE);
//ASSMMHHDD
for (i = 0; i < 4; i++) {
time[i] = (cmd[2 * i + 1] - 48) * 10 + cmd[2 * i + 2] - 48; // ss, mm, hh, dd
byte flags[5] = { 0, 0, 0, 0, 0 };
DS3231_set_a1(time[0], time[1], time[2], time[3], flags);
} else if (cmd[0] == 66 && cmdsize == 7) { // "B" Set Alarm 2
DS3231_set_creg(DS3231_INTCN | DS3231_A2IE);
//BMMHHDD
time[i] = (cmd[2 * i + 1] - 48) * 10 + cmd[2 * i + 2] - 48; // mm, hh, dd
byte flags[5] = { 0, 0, 0, 0 };
DS3231_set_a2(time[0], time[1], time[2], flags);
} else if (cmd[0] == 67 && cmdsize == 1) { // "C" - get temperature register
Serial.print("temperature reg is ");
Serial.println(DS3231_get_treg(), DEC);
} else if (cmd[0] == 68 && cmdsize == 1) { // "D" - reset status register alarm flags
reg_val = DS3231_get_sreg();
reg_val &= B11111100;
DS3231_set_sreg(reg_val);
} else if (cmd[0] == 70 && cmdsize == 1) { // "F" - custom fct
reg_val = DS3231_get_addr(0x5);
Serial.print("orig ");
Serial.print(reg_val, DEC);
Serial.print("month is ");
Serial.println(bcdtodec(reg_val & 0x1F), DEC);
} else if (cmd[0] == 71 && cmdsize == 1) { // "G" - set aging status register
DS3231_set_aging(0);
} else if (cmd[0] == 83 && cmdsize == 1) { // "S" - get status register
Serial.print("status reg is ");
Serial.println(DS3231_get_sreg(), DEC);
Serial.print("unknown command prefix ");
Serial.println(cmd[0]);
Serial.println(cmd[0], DEC);
void printMonth(int month)
switch (month)
case 1: lcd.print(" January "); break;
case 2: lcd.print(" February "); break;
case 3: lcd.print(" March "); break;
case 4: lcd.print(" April "); break;
case 5: lcd.print(" May "); break;
case 6: lcd.print(" June "); break;
case 7: lcd.print(" July "); break;
case 8: lcd.print(" August "); break;
case 9: lcd.print(" September "); break;
case 10: lcd.print(" October "); break;
case 11: lcd.print(" November "); break;
case 12: lcd.print(" December "); break;
default: lcd.print(" Error "); break;
void digitalwrite(int relay)
digitalWrite(RELAY2, LOW); // Turns ON Relays 2
digitalWrite(RELAY3, LOW); // Turns ON Relays 3
digitalWrite(RELAY4, LOW); // Turns ON Relays 4
digitalWrite(RELAY1, LOW); // Turns ON Relays 1
delay(2000); // Wait 2 seconds
digitalWrite(RELAY1, HIGH); // Turns Relay Off
delay(6000); // Wait 6 seconds
digitalWrite(RELAY2, HIGH); // Turns Relay Off
digitalWrite(RELAY3, HIGH); // Turns Relays off
digitalWrite(RELAY4, HIGH); // Turns Relay Off
delay(6000);
