Hello there,
I’m using this code to create multiple fading LEDs. As of right now, they go from bright to low, and then low to bright. My question is, how would I go about (if it’s possible) making the LEDs fade from low to bright, and then staying at that max value (keeping the brightness at 255)?
Thank you in advance!
I guess I should also post the code here so people don’t have to download it.
(Even better with Code tags - Moderator)
int led1 = 9; // the PWM pin the LED is attached to
int led2 = 6;
int led3 = 3;
int brightness1 = 0; // how bright the LED is
int brightness2 = 100;
int brightness3 = 200;
int fadeAmount1 = 5; // how many points to fade the LED by
int fadeAmount2 = 5;
int fadeAmount3 = 5;
// the setup routine runs once when you press reset:
// declare pin 9 to be an output:
pinMode(led1, OUTPUT);
pinMode (led2, OUTPUT);
pinMode (led3, OUTPUT);
// the loop routine runs over and over again forever:
// set the brightness of pin 9:
analogWrite(led1, brightness1);
analogWrite(led2, brightness2);
analogWrite(led3, brightness3);
// change the brightness for next time through the loop:
brightness1 = brightness1 + fadeAmount1;
brightness2 = brightness2 + fadeAmount2;
brightness3 = brightness3 + fadeAmount3;
// reverse the direction of the fading at the ends of the fade:
if (brightness1 <= 0 || brightness1 >= 250) {
fadeAmount1 = -fadeAmount1;
}else if (brightness2 <= 0 || brightness2 >= 250) {
fadeAmount2 = -fadeAmount2;
}else if (brightness3 <= 0 || brightness3 >= 250) {
fadeAmount3 = -fadeAmount3;
delay(30);
My question is, how would I go about (if it's possible) making the LEDs fade from low to bright, and then staying at that max value (keeping the brightness at 255)?
Remove the code that makes the, fade back down.
You'll still need to deal with what happens when the LEDs reach full brightness. That is, you need to stop incrementing the brightnessN variables when that happens (and probably stop writing to the pins).
