Reversing LED state
Hi there, I feel a bit silly for asking as I feel like this should be a very straightforward and simple change to make in comparison to what I needed help with earlier, but here I am anyway.
I have been working on a circuit that consists of six FSR sensors, a push button and an LED. With the push of the button, I can stop the recording of data; in the serial monitor, the lines would be blank, and the serial plotter would pause. Now I would like to add an LED so that I can see when the data is being recorded more visually.
The problem is that the LED state is reversed from what I would like it to do. Meaning that the LED is off when the data is being recorded and turning on when the recording stops. Is there a way to reverse the LED state? All attempts I have made to change the states have resulted in the LED not working at all. I have attached the current code and setup below.
Thank you in advance and have a lovely day!
// References
// Innitial starting code for reading the FSR's https://forum.arduino.cc/t/separating-fsr-values-and-labelling-graph/1275362
// Innitial starting code for including a LED and button https://roboticsbackend.com/arduino-turn-led-on-and-off-with-button/
// Own post on Arduino Forum https://forum.arduino.cc/t/arduino-only-showing-3-out-of-6-outputs-on-serial-plotter/1361263
// Innitial cirquit reference for the FSR's https://forum.arduino.cc/t/connecting-8-fsrs-to-arduino-mega/618577
// Innitial cirquit source for the LED and Button https://techexplorations.com/guides/arduino/sensors/button/
#define LED_PIN 7
#define BUTTON_PIN 8
// Defining pins
const byte PinFsr [] = {A0, A1, A2, A3, A4, A5};                // Location of the six FSR's
const  byte Nfsr = sizeof(PinFsr);                              // Number of bytes occupied
byte prevButtonState = HIGH;                                    // Button being pressed
byte buttonState = LOW;                                         // Button not being pressed
byte lastButtonState = LOW;
byte loopRunning = LOW;
byte ledState = LOW;
unsigned long debounceDuration = 50; // millis
unsigned long lastTimeButtonStateChanged = 0;
  Serial.begin (9600);                                          // Begin serial communication at a baud rate of 9600
  pinMode(LED_PIN, OUTPUT);
  pinMode(BUTTON_PIN, INPUT);
if(loopRunning) {
    for (byte n = 0; n < Nfsr; n++)  {                          // Reading data from all FSR's simultaneously
        int fsr = analogRead (PinFsr [n]);
        Serial.print (fsr);Serial.print(" ");
        Serial.print (",");                                     // Separate values with a comma
    Serial.println ();                                          // Display values on Serial Plotter and Serial Monitor
    delay (500);                                                // Delay 500 Milliseconds
if (millis() - lastTimeButtonStateChanged > debounceDuration) {
  byte buttonState = digitalRead(BUTTON_PIN);
    if (buttonState != lastButtonState) {
     lastTimeButtonStateChanged = millis();
     lastButtonState = buttonState;
     if (buttonState == LOW) {
       ledState = (ledState == HIGH) ? LOW: HIGH;
       digitalWrite(LED_PIN, ledState);
  buttonState = digitalRead(BUTTON_PIN);                         // If the current button state differs from previous, toggle other way
  if((buttonState==LOW) && (prevButtonState==HIGH)) {
    loopRunning = !loopRunning;
    prevButtonState=buttonState;
      pinMode(LED_PIN, OUTPUT);                                  // LED works as an output
      pinMode(BUTTON_PIN, INPUT);                                // Button works as an imput
You only need to set pin mode once in setup() so remove them from loop.
To change the LED state just reverse the LOW : HIGH
Also your LED is Backwards
Well, first thing I noticed is you use a timer for the debounce: I suggest you to use a hardware debounce and get rid of that timer.
Then, please use a better code indentation, it helps you (and us) to ease the code flow interpretation.
Then, here you handle the button and the led:
I can't get why you added all this stuff here, e.g. reading BUTTON_PIN twice and a lot of if()s, and redundant variables. And you don't need to use "pinMode()" on the loop(), unless you really need to do so. Get rid of those two last lines.
What you need to do here when the button has been pressed is just "reverse" the operating flag (loopRunning) and LED output accordingly. And the best tip is to make use of comments to clarify what that code portion does (describe it to you first, because if you take an old code you could have forgot the logic behind, but also for us to better understand why you used certain instructions and variables).
Ad use "boolean" variables if you need just flags, like "loopRunning".
So, you don't need all that mess, try just this block I wrote "on the fly" for you:
  // Ignore the button unless the "debounce time" is over
    // Ok, what's the button state?
      // State has changed, record it
    // Now if the button has been pressed, reverse the loop status and LED
    if (buttonState == HIGH) {
      digitalWrite(LED_PIN, loopRunning);
PS: when in trouble or you need some more deeper debug procedure, I always advise to even use emulators like "Wokwi" or "TinkerCAD Circuits" to make debug sessions easier and quicker than using the "real" board...
@jim-p @docdoc Thank you both for your observations and suggestions!
  • I have switched around the LED to be in the correct position (not one of my brightest moments)
  • I have tried to change the LED state by reversing LOW : HIGH; the LED stopped doing anything altogether.
  • I made an attempt to make the code neater by using indentations; I'm sorry for the mess; coding etiquettes (and coding in general) are still quite new to me.
  • For now, I will keep in the software debounce as I have no idea how to do a hardware one, but I will look into that.
  • I tried to implement the suggestions and code provided, but the LED is not working at all. I have included the adjusted code below. Probably made a typo somewhere.
// References
#define LED_PIN 7
// Defining pins
const byte PinFsr[] = { A0, A1, A2, A3, A4, A5 };  // Location of the six FSR's
boolean (loopRunning) = LOW;
  Serial.begin(9600);  // Begin serial communication at a baud rate of 9600
  if (loopRunning) {
      int fsr = analogRead(PinFsr[n]);
      Serial.print(fsr);
      Serial.print(" ");
      Serial.print(",");  // Separate values with a comma
  Serial.println();  // Display values on Serial Plotter and Serial Monitor
  delay(500);  // Delay 500 Milliseconds
  if (millis() - lastTimeButtonStateChanged > debounceDuration) {  // Wait for debounce time to pass before reading button state
    byte buttonState = digitalRead(BUTTON_PIN);  // Read button state
    if (buttonState != lastButtonState) {  // Record state change
    if (buttonState == HIGH) {  // If button is pressed, reverse loop and LED state
I'm tuning in late. If your LED is literally on when it should be off and vice versa, this should be easy.
You could flip the controlling variable after writing to the LED:
or
     digitalWrite(LED_PIN, loopRunning ? LOW : HIGH);
and if that is exactly wrong, switch the rolls of LOW and HIGH, viz:
     digitalWrite(LED_PIN, loopRunning ? HIGH : LOW);
HTH and is that what you meant?
BTW I'll spare other comments, but
boolean loopRunning = false;
true and false for Boolean variables; use LOW and HIGH only with digitslWrite() and digitalRead().
When you can explain why, you'll know more about the mysteries that be.
a7
Glad to have you. And yes that is exactly the problem.
I have tried all your suggestions and adjusted the boolean (thank you for the short explanation, I do get the difference now)
Sadly, the LED is still not doing anything :frowning:
EDIT: I switched the LED back around on the breadboard and it seems to be working now :smiley: I wish I could award all of you with the green checkmark. Nevertheless, thank you all very much your your time and patience
That's right. I said it was written "on the fly", so a small mistake is possible. :wink:
Yes, I have seen some LEDs that actually have the anode on the flat side but it's rare
