Hi there,
I'm new to coding and have written a code for a Reversing sensor, which consists of an ultrasonic sensor, LED, and LCD using an Arduino Mega 2560.
I managed to get the sensor and display to work properly using sample code templates but I want to take it a step further and trigger a 'LED' or a 'Buzzer' if the measurement is less than 5cm.
I have researched and tried a few things but always end up with the following error:
/Users/logic101/Documents/Arduino/Car_Reverse_Sensor_Practise/Car_Reverse_Sensor_Practise.ino: In function 'void loop()':
/Users/logic101/Documents/Arduino/Car_Reverse_Sensor_Practise/Car_Reverse_Sensor_Practise.ino:56:19: warning: ISO C++ forbids comparison between pointer and integer [-fpermissive]
if ("Distance" <= 4);
I would be grateful if someone can have a look over my code below and error as above and provide some guidance on how I can make the 'LED' or 'Buzzer' turn on at a specific measurement is reached.
See below for actual code that contains the error.
#include <LiquidCrystal.h>
#define trigger 18
#define echo 19
int led = 9;
LiquidCrystal lcd(2,3,4,5,6,7);
float time=0,distance=0;
lcd.begin(16,2);
pinMode(trigger,OUTPUT);
pinMode(echo,INPUT);
pinMode(led,OUTPUT);
pinMode(led, OUTPUT);
lcd.print(" Car Reverse ");
lcd.setCursor(0,1);
lcd.print(" Sensor ");
delay(3000);
lcd.clear();
lcd.print(" Distance Meter");
delay(3000);
lcd.clear();
lcd.print("logic101's Creation");
lcd.setCursor(0,1);
lcd.print ("DCC Y8 Science");
delay(3000);
lcd.clear();
digitalWrite(trigger,LOW);
delayMicroseconds(2);
digitalWrite(trigger,HIGH);
delayMicroseconds(10);
time=pulseIn(echo,HIGH);
distance=time*340/20000;
lcd.clear();
lcd.print("Distance:");
lcd.print(distance);
lcd.print("cm");
lcd.setCursor(0,1);
lcd.print(distance/100);
lcd.print("m");
delay(100);
digitalWrite(led, HIGH);
