.rewind() making sound replay nonstop
Hey all,
I'm trying to play a sound when someone scores.
I have it working for score1 - so the first time CPU plays sound1 but then it stops and doesn't work again.
I watched a tutorial and it said you need .rewind() to reset the sound so it will play again I added it but it sounds like a chainsaw. It keeps on looping.
import processing.serial.*; // Import the Processing Serial Library for communicating with arduino
import ddf.minim.*;
Minim minim;
AudioPlayer sound1, sound2, sound3, sound4;
Serial myPort;
int CPU_SCORE;
int PLAYER_SCORE;
  size(500, 500);
  println(Serial.list()); // Prints the list of serial available devices (Arduino should be on top of the list)
  myPort = new Serial(this, Serial.list()[1], 9600); // Open a new port and connect with Arduino at 9600 baud
  minim = new Minim(this);
  sound1 = minim.loadFile("roundLose.wav");
  sound2 = minim.loadFile("gameLose.wav");
  sound3 = minim.loadFile("gameWin.mp3");
  sound4 = minim.loadFile("roundWin.wav");
void draw()
  if(CPU_SCORE == 1) {
    sound1.play();
    sound1.rewind();
  if(CPU_SCORE == 2) {
    sound1.play();
    sound1.rewind();
  if(CPU_SCORE == 3) {
    sound1.play();
    sound1.rewind();
  else if(CPU_SCORE == 4) {
    sound1.play();
    sound1.rewind();
  if(CPU_SCORE == 5) {
    sound1.play();
    sound1.rewind();
  if(CPU_SCORE == 6) {
    sound1.play();
    sound1.rewind();
  if(CPU_SCORE == 7) {
    sound1.play();
    sound1.rewind();
  if(CPU_SCORE == 8) {
    sound2.play();
  print(CPU_SCORE);
  println(PLAYER_SCORE);
void serialEvent(Serial myPort) // Is called everytime there is new data to read
  if (myPort.available() > 1)
    String completeString = myPort.readStringUntil(10); // Read the Serial port until there is a linefeed/carriage return
    if (completeString != null) // If there is valid data insode the String
      trim(completeString); // Remove whitespace characters at the beginning and end of the string
      String seperateValues[] = split(completeString, ","); // Split the string everytime a delimiter is received
      CPU_SCORE = int(seperateValues[0]);
      PLAYER_SCORE = int(seperateValues[1]);
(deleted)
there you go sorry
Ardi2743:
there you go sorry
What about the rest of it ?
Please read How to use this forum and follow the advice re posting code using code tags
update sorry again! :frowning:
The code now in your original post is not Arduino code. It looks very much like it is Processing code.
Is your problem with the Arduino or with Processing ?
yeah it's with processing I didn't even think about it being an issue, sorry I'm new to all this.
(deleted)
spycatcher2k:
This is not the processing forum, this is the ARDUINO forum! :slight_smile:
But you need to play the sound when the score changes, have a flag that is set when the score changes, and only play the sound when the flag is set AND the score is at a value, then reset the plag in the play calling function.
Psudo code:
bool flag = false;
check if i need to add to the score;
if i do
score++;
flag = true;
if(score == 2 && flag == true)
{Playsound;
rewind;
flag = false;
Thank you! Yeah that's my bad xD
