rewrite function from struct
I’m building a clock that uses the LPD6803 lib from ladyada. Since the clock crashes a lot I want to “port” the clock to this fastspi lib. Trust me when I say I’m a novice programmer… I managed to change most of the code but I don’t understand how to rewrite the struct (?). h=actual hour (led nr), 0,0,brightness is RGB values.
strip.setPixelColor(h, 0, 0, brightness);
should become something like this: (0=led nr and should become h, m and s variable)
leds[0].r = 0;
  leds[0].b = 0;
  leds[0].g = 0;
Th is the entire code. Most is done but the above part I don’t understand.
// LPD6803 SPI pins
//dataPin = 11;       // 'white' wire
//clockPin = 13;      // 'green' wire
//DS1307 pins
//SDA = A4
//SCL = A5
//SQW = 2
//include needed libraries
#include <FastSPI_LED.h>
#include <Wire.h>
#include "RTClib.h"
// RTC_Millis is for a soft rtc
RTC_DS1307 RTC;
#define NUM_LEDS 60
struct CRGB { unsigned char r; unsigned char g; unsigned char b; };
struct CRGB *leds;
// LDR pin
int LDRPin = A2;
// LDR value
int LDRValue;
// Brightness fade up (1 or 2) depens on LDR reading
int z;
// Set brightness min 6, max 31.
int MinBright = 6;
int MaxBright = 31;
int brightness;
// Define second, minute, hour
int s;
int m;
int h;
  Serial.begin(19200);
  Wire.begin();
  RTC.begin();
    // following line sets the RTC to the date & time this sketch was compiled
    RTC.adjust(DateTime(__DATE__, __TIME__));
  // set 1hz sqw on DS1307 pin 7, we will using this for a interrupt on arduino pin 2
  Wire.beginTransmission(0x68);              // write the control register
  Wire.send(0x07);                           // register address 07H)
  Wire.send(0x90);                           // 0x90=1Hz, 0x91=4kHz, 0x92=8kHz, 0x93=32kHz
  Wire.endTransmission();
  //Attach pin 7 from DS1307 to Arduino pin 2 and call function clock
  attachInterrupt(0, clock, FALLING);
  FastSPI_LED.setLeds(NUM_LEDS);
  FastSPI_LED.setChipset(CFastSPI_LED::SPI_LPD6803);
  FastSPI_LED.setDataRate(2); //set pixel data rate
  FastSPI_LED.init();
  FastSPI_LED.start();
  leds = (struct CRGB*)FastSPI_LED.getRGBData();
} //end setup
// Empty loop, all is done by the 1hz interupt on pin 2
void loop () { }
void clock() {
    interrupts(); //start all interupts again.
  //attach Interrupt stops the strip, so start it again
  //strip.begin();
  FastSPI_LED.show();
  //Get current time
  DateTime now = RTC.now();
  // mapping hour 24 => 12 => 60 (hour hand)
  m = now.minute(), DEC;
  s = now.second(), DEC;
  h = now.hour(), DEC;
  if (h >= 12) { h = h - 12; }
  else if (h = 12) { h = 0; }
  h = map(h, 0, 12, 0, 60);
  if ( m <= 6 ) { h == h; }
  else if ( m <= 18 ) { h = h + 1; }
  else if ( m <= 30 ) { h = h + 2; }
  else if ( m <= 42 ) { h = h + 3; }
  else if ( m <= 54 ) { h = h + 4; }
    // Get LDR vaulue and set brightness
    LDRValue = analogRead(LDRPin);
    brightness = map(LDRValue, 0, 1023, MaxBright, MinBright);
    // set increase step
    if ( brightness < 20 ) {
      z = 1;
      z = 2;
    strip.setPixelColor((m - 1), 0, 0, 0);
    strip.setPixelColor((s - 2 ), 0, 0, 0);
    strip.setPixelColor((s - 3 ), 0, 0, 0);
    // clear transistion from 59 -> 0
    if (s == 0) { strip.setPixelColor((58), 0, 0, 0); }
    if (s == 1) { strip.setPixelColor((59), 0, 0, 0); }
    if (m == 0) { strip.setPixelColor((59), 0, 0, 0); }
    //start fade up/down
    for (int y = 1; y < brightness; y = y + z) {
         strip.setPixelColor((s - 1 ), (brightness - y), 0, 0);
         if (s == 0) { strip.setPixelColor(59, (brightness - y), 0, 0); }
         strip.setPixelColor(s, brightness, 0, 0);
         strip.setPixelColor((s + 1 ), y, 0, 0);
         if (s == 59) { strip.setPixelColor(0, y, 0, 0); }
         strip.setPixelColor(m, 0, brightness, 0);
         // second equals minute
         if ((s + 1) == m) { strip.setPixelColor(s + 1, y, brightness, 0); }
         if (s == m) { strip.setPixelColor(s, brightness, brightness, 0); }
         if ((s - 1) == m) { strip.setPixelColor(s - 1, (brightness - y), brightness, 0); }
         // second equals hour
         if ((s + 1) == h) { strip.setPixelColor(s + 1, y, 0, brightness); }
         if (s == h) { strip.setPixelColor(s, brightness, 0, brightness); }
         if ((s - 1) == h) { strip.setPixelColor(s - 1, (brightness - y), 0, brightness); }
         // update strip
         //strip.show();
         FastSPI_LED.show();
         delay(105 - (2 * y));
   // Debug
    //Serial.print(now.year(), DEC);
    //Serial.print('/');
    //Serial.print(now.month(), DEC);
    //Serial.print(now.day(), DEC);
    //Serial.print(' ');
    //Serial.print(now.hour(), DEC);
    //Serial.print(':');
    //Serial.print(now.minute(), DEC);
    //Serial.print(now.second(), DEC);
    //Serial.println();
    Serial.print("raw LDR reading = ");
    Serial.println(LDRValue);     // the raw analog reading
    Serial.print("mapped brightness level = ");
    Serial.println(LDRPin);     // the analog level
    Serial.print("brightness level = ");
    Serial.println(brightness);     // the calculated level
You probably want an array of structures:
#define NUM_LEDS 60
struct CRGB leds[NUM_LEDS];
That can be shortened to:
#define NUM_LEDS 60
struct CRGB { unsigned char r; unsigned char g; unsigned char b; } eds[NUM_LEDS];
A struct is a way of grouping several variables together under a common name. The variables in the struct do not have to be the same type.
A common example (outside of the Arduino IDE) was an address record or struct(ure) you hade name, address, zip, soc.sec.no, and other realted data all stuck in 1 struct because of their relationship.
so - you have created a struct with values for the 3 colors at that point - struct CRGB { unsigned char r; unsigned char g; unsigned char b; }; this is desctibing a record with the values for R, G ,& B
You then describe another struct using the same name (probably adds to the confusion) that is an array of the previous struct
I would have thought you would have done this - struct CRGB { unsigned char r; unsigned char g; unsigned char b; }; and use it as a new type , and then define an array - CRGB leds[60];
and you would address them as leds[1].r, leds[1].g and leds[1].b
You are calling a function - strip.setPixelColor((m - 1), 0, 0, 0); which probably has something like this - strip.setpixel (int index, unsigned char red; unsigned char green; unsigned char blue) and has code something like this - leds[index].r=red; leds[index].g=green; leds[index].b=blue; ... but this allows you to work with a "variable" called leds[] that contains multiple values, but to be handled as one chunk.
