Rewrite part of the example code from Adafruit FONA
Recently, I bought the FONA 800 shield from Adafruit. I have got it running with the examples and it plays very nicely.
I want to use the part of the example code which handles a call in my own sketch. The example code waits for a number to call which should be entered in the serial. I want to do the exact same thing, just with the phone number supplied from a variable in Arduino.
I have two possibilities: To supply the whole number when the call should be performed and to build up let's say an array every time a number is entered.
The code for performing a call:
// call a phone!
    char number[30];
    flushSerial();
    Serial.print(F("Call #"));
    readline(number, 30);
    Serial.print(F("Calling ")); Serial.println(number);
    if (!fona.callPhone(number)) {
      Serial.println(F("Failed"));
      Serial.println(F("Sent!"));
The flushSerial function:
void flushSerial() {
  while (Serial.available())
  Serial.read();
And the readline function:
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout) {
uint16_t buffidx = 0;
boolean timeoutvalid = true;
if (timeout == 0) timeoutvalid = false;
while (true) {
  if (buffidx > maxbuff) {
    //Serial.println(F("SPACE"));
while (Serial.available()) {
  char c =  Serial.read();
  //Serial.print(c, HEX); Serial.print("#"); Serial.println(c);
  if (c == '\r') continue;
  if (c == 0xA) {
    if (buffidx == 0)   // the first 0x0A is ignored
      continue;
    timeout = 0;         // the second 0x0A is the end of the line
  buff[buffidx] = c;
  buffidx++;
if (timeoutvalid && timeout == 0) {
  //Serial.println(F("TIMEOUT"));
  delay(1);
  buff[buffidx] = 0;  // null term
  return buffidx;
It is the readline function which should be edited. Right now it retrieves the number entered from serial.
I am kind of a newbie myself so I am not that familiar with data types and so on.
Thank you very much for any answers.
What have you tried?
Paul
So something like:
// call a phone!
    char number[] = "5558675309";
