Rewriting existing Display Code to Serial Code
Hi
I am currently struggeling with rewriting an existing Display Code into an Serial only code.
The original Code structure has a menu that is navigated via 6 switches (sw).
I added the schematics to this post, which I build on a bread board. Instead of the arduino mini I used an DUE, so I can work with 3.3V and do not need to use the battery (bottem left in schematics). In top left side is a SFP-Port, which is converted into an optical meter, which sends and recieves light impulses. I want to read out those impulses via the serial monitor and not the display (top right corner of the schematics). The problem in my code probably lies in the menu structure.
So here is the original code, in which i only noted out (//) the functions that I think I do not need. I mainly changed the display.print and display.println to Serial.print and Serial.println and tried to note out the menu navigation. But I am getting no reading at all in the Serial monitor.
The first two libaries (ddm.h, catbin.h) are from:GitHub - oakkar7/ddm: Arduino Lib for SFP module control and diagnostics with DDM protocol
the original creator of this project. Here is the link to the project on hackaday, which I am trying to recreate (Optical Power Meter (with SFP and DDM protocol) | Hackaday.io
Code Part 1:
#include <catbin.h>
#include <ddm.h>
#include <SPI.h>
    //#include <Adafruit_GFX.h>
    //#include <Adafruit_PCD8544.h>
#include <Wire.h>
#include <math.h>
// Creating an object of SFP DDM library
ddm sfp;
// input pins for ALM
const int TX_fault =  8;      // TX en LED pin
const int LOS =  9;           // TX en LED pin
// output pin for CTL
const int TX_disable =  10;   // TX en, 0 = TX ensble ,1= disable ,
// status LEDs
const int TX_led =  A2;     // TX en LED pin
const int RX_led = A3;      // LOS LED pin
const int TX_sw =  11;      // LOS LED pin
const int ES_sw =  12;      // LOS LED pin
const int UP_sw =  A0;      // LOS LED pin
const int DN_sw =  A1;      // LOS LED pin
const int FN_sw =  A6;      // LOS LED pin
const int EN_sw =  A7;      // LOS LED pin
boolean debug_flag = 1;
boolean TX_status = 0;
boolean RX_status = 0;
boolean V_status = 0;
float temp_t;
float volts;
float optical_tx;
float optical_rx;
boolean temp_hi, temp_low, vcc_hi, vcc_low, tx_hi, tx_low, rx_hi, rx_low;
boolean temp_hi_warn, temp_low_warn, vcc_hi_warn, vcc_low_warn, tx_hi_warn, tx_low_warn, rx_hi_warn, rx_low_warn;
unsigned char  cur_menu = 5;
// Software SPI (slower updates, more flexible pin options):
// pin 7 - Serial clock out (SCLK)
// pin 6 - Serial data out (DIN)
// pin 5 - Data/Command select (D/C)
// pin 4 - LCD chip select (CS)
// pin 3 - LCD reset (RST)
        // Adafruit_PCD8544 display = Adafruit_PCD8544(7, 6, 5, 4, 3);
// Setup/Init Everything
void setup()   {
  pinMode(TX_disable, OUTPUT);        // TX en, GND = TX end,
  pinMode(TX_fault, INPUT_PULLUP);    // TxFault , 1 = OK, 0 = Fault
  pinMode(LOS, INPUT_PULLUP);         // LOS, 1 = OK, 0 = LOS
  pinMode(TX_sw, INPUT_PULLUP);
  pinMode(TX_led, OUTPUT);
  pinMode(RX_led, OUTPUT);
  pinMode(FN_sw, INPUT);
  pinMode(EN_sw, INPUT);
  pinMode(UP_sw, INPUT_PULLUP);
  pinMode(DN_sw, INPUT_PULLUP);
  pinMode(ES_sw, INPUT_PULLUP);
  Wire.begin();
Verschaltungs Schema.pdf (74.3 KB)
Code Part 2:
//  display.begin();
  // LCD init done
  // you can change the contrast around to adapt the display
//  display.setContrast(60);
//  showSplash();
  digitalWrite(TX_disable, HIGH);    // Enable Laster TX
 while (1) {
  checkSW();
  sfp.DDM_All_Read ();
  volts = sfp.getVolts();
  temp_t = sfp.getTemp();
  optical_rx = sfp.getRX();
  optical_tx = sfp.getTX();
  checkALM();
///   if (cur_menu == 5) showTXRX();
///   if (cur_menu == 4) showRX();
///   if (cur_menu == 3) showTX();
///   if (cur_menu == 2) showDetails();
///   if (cur_menu == 1) showSystem();
  if (debug_flag)
  sfp.debugDDM();
  //getINFO();
  sfp.getALM(temp_hi, temp_low, vcc_hi, vcc_low, tx_hi, tx_low, rx_hi, rx_low);
  sfp.getWARN(temp_hi_warn, temp_low_warn, vcc_hi_warn, vcc_low_warn, tx_hi_warn, tx_low_warn, rx_hi_warn, rx_low_warn);
// Check Switches
void checkSW()
  // check TX SW
  if (digitalRead(TX_sw) == LOW)
    delay(100);
    if (TX_status == 1)
      TX_status = 0;
      TX_status = 1;
    Serial.println(TX_status);
  if (TX_status == 1)
    digitalWrite(TX_led, LOW);
  if (TX_status == 0)
    digitalWrite(TX_disable, LOW);
    digitalWrite(TX_led, HIGH);
  //check menu
   int FN_sw = analogRead(A6) > 256 ? 0 : 1;
  if (FN_sw == 1)
    processMenu();
    //delay(100);
  //check Escape/Cancel SW
  if (digitalRead(ES_sw) == LOW)
    showSplash();
///     if (cur_menu > 5) cur_menu = 5;
///     if (cur_menu < 1) cur_menu = 1;
// Check Switches-2
void checkSW2()
  //check UP SW
  int UP_sw = analogRead(A0) > 256 ? 0 : 1;
  if (UP_sw == 1)
    cur_menu++;
  //check Down SW
  int DN_sw = analogRead(A1) > 256 ? 0 : 1;
  if (DN_sw == 1)
    cur_menu--;
    showSplash();
// Check Alarms
void checkALM()
    if ( 30 > optical_rx  && optical_rx > -40)
      digitalWrite(RX_led, HIGH);
      RX_status = 1;
   digitalWrite(RX_led, LOW);
   RX_status = 0;
// process menu
void processMenu()
{ int EN_sw = 0;
  while (EN_sw == 0)
    checkSW2();
    showMenu();
    EN_sw = analogRead(A7) > 256 ? 0 : 1;
    delay(300);
// display menu
void showSplash()
    // miniature splash display
//  display.clearDisplay();
//  display.drawBitmap(0, 0,  cat1, 84, 48, 1);
//  display.setTextSize(1);
//  display.setTextColor(BLACK);
//  display.setCursor(0,0);
    Serial.println("IT");
//  display.setCursor(0,10);
    Serial.println("IS");
//  display.setCursor(0,20);
  Serial.println("Turning");
//  display.setCursor(0,30);
  Serial.println("ON");
//  display.setCursor(0,40);
//  display.println("?!");
//  display.display();
  // text about
  Serial.println("    Optical");
  //display.setTextSize(2);
//  display.setTextColor(WHITE, BLACK); // 'inverted' text
  Serial.println(" POWER METER  ");
  Serial.println("     v1.0  ");
  //display.setTextSize(1);
//  display.println("      By");
//  display.println("XXXX");
void showMenu()
  // text display tests
//  else
  Serial.println("1.TX/RX Power");
//  else
  Serial.println("2.TX Power");
//  else
  Serial.println("3.TX Power");
//  else
  Serial.println("4.Details");
//  else
  Serial.println("5.System Setup");
void showTX()
  Serial.print("TX Power:");
   Serial.println("dbm");
//  display.setTextSize(2.5);
//  display.setCursor(0,15);
  Serial.print(optical_tx);
  showStatus();
void showRX()
  Serial.print("RX Power:");
  Serial.print(optical_rx);
  showStatus();
void showTXRX()
  Serial.println("RX Power:");
//  display.setTextSize(2);
//  display.setCursor(0,9);
//  display.setCursor(64,15);
//  display.setCursor(0,27);
  Serial.print("TX: ");
//  display.setCursor(0,33);
//  display.setCursor(64,27);
//  display.println("dbm");
  showStatus();
// show status/alarm in bottom bar
void showStatus()
  Serial.println("TX:    RX:");
//  display.setCursor(18,40);
  if (TX_status == 0)
  Serial.print("EN");
  Serial.print("NA");
//  display.setCursor(60,40);
  if (RX_status == 1)
  Serial.print("OK ");
  Serial.print("LOS");
// show detailed one screen
void showDetails()
  Serial.println("Temp   :");
  Serial.println("Volt   :");
  Serial.println("TXPower:");
  Serial.println("RXPower:");
  Serial.println("Alarms :");
  //update
//   display.setCursor(48,0);
  Serial.println(temp_t);
//  display.setCursor(48,10);
  Serial.println(volts);
//  display.setCursor(48,20);
  Serial.println(optical_tx);
//  display.setCursor(48,30);
  Serial.println(optical_rx);
void  showSystem()
  Serial.println("Unit   :");
  Serial.println("Current:");
  Serial.println("Version:");
// EOF
The Serial monitor should, from my understanding, at least print out the first part:
// display menu
void showSplash()
because it is not connected to the menu and is the "Starting screen".
I am still new to this and thankful for any suggestions and comments.
Thanks in advance
