I have a demo project to create radar 360 degrees. Problem is a size of radar schematics. How to rezise scheme ?
Tnh for the answers.
import processing.serial.*; // imports library for serial communication
import java.awt.event.KeyEvent; // imports library for reading the data from the serial port
import java.io.IOException;
Serial myPort; // defines Object Serial
// defubes variables
String angle="";
String distance="";
String data="";
String noObject;
float pixsDistance;
int iAngle, iDistance;
int index1=0;
int index2=0;
PFont orcFont;
size (1920, 1080);
smooth();
myPort = new Serial(this,"COM3", 9600); // starts the serial communication
myPort.bufferUntil('.'); // reads the data from the serial port up to the character '.'. So actually it reads this: angle,distance.
orcFont = loadFont("Arial-Black-20.vlw");
void draw() {
fill(98,245,31);
textFont(orcFont);
// simulating motion blur and slow fade of the moving line
noStroke();
fill(0,4);
rect(0, 0, width, 1010);
fill(98,245,31); // green color
// calls the functions for drawing the radar
drawRadar();
drawLine();
drawObject();
drawText();
void serialEvent (Serial myPort) { // starts reading data from the Serial Port
// reads the data from the Serial Port up to the character '.' and puts it into the String variable "data".
data = myPort.readStringUntil('.');
data = data.substring(0,data.length()-1);
index1 = data.indexOf(","); // find the character ',' and puts it into the variable "index1"
angle= data.substring(0, index1); // read the data from position "0" to position of the variable index1 or thats the value of the angle the Arduino Board sent into the Serial Port
distance= data.substring(index1+1, data.length()); // read the data from position "index1" to the end of the data pr thats the value of the distance
// converts the String variables into Integer
iAngle = int(angle);
iDistance = int(distance);
void drawRadar() {
pushMatrix();
translate(960,500); // moves the starting coordinats to new location
noFill();
strokeWeight(2);
stroke(98,245,31);
// draws the circle lines
circle(0,0,200);
circle(0,0,400);
circle(0,0,600);
circle(0,0,800);
circle(0,0,1000);
// draws the angle lines
line(0,0,-500*cos(radians(30)),-500*sin(radians(30)));
line(0,0,-500*cos(radians(60)),-500*sin(radians(60)));
line(0,0,-500*cos(radians(90)),-500*sin(radians(90)));
line(0,0,-500*cos(radians(120)),-500*sin(radians(120)));
line(0,0,-500*cos(radians(150)),-500*sin(radians(150)));
line(0,0,-500*cos(radians(210)),-500*sin(radians(210)));
line(0,0,-500*cos(radians(240)),-500*sin(radians(240)));
line(0,0,-500*cos(radians(270)),-500*sin(radians(270)));
line(0,0,-500*cos(radians(300)),-500*sin(radians(300)));
line(0,0,-500*cos(radians(330)),-500*sin(radians(330)));
line(-580*cos(radians(30)),0,500,0);
popMatrix();
void drawObject() {
pushMatrix();
strokeWeight(15);
stroke(255,10,10); // red color
pixsDistance = iDistance*10; // covers the distance from the sensor from cm to pixels
// limiting the range to 50 cms
if(iDistance<50){
// draws the object according to the angle and the distance
point(pixsDistance*cos(radians(iAngle*-1)),-pixsDistance*sin(radians(iAngle*-1)));
popMatrix();
void drawLine() {
pushMatrix();
strokeWeight(5);
stroke(30,250,60);
line(0,0,500*cos(radians(iAngle*-1)),-500*sin(radians(iAngle*-1))); // draws the line according to the angle
popMatrix();
void drawText() { // draws the texts on the screen
pushMatrix();
if(iDistance>50) {
noObject = "";
else {
noObject = "Aircraft detected";
fill(0,0,0);
noStroke();
rect(0, 1010, width, 1080);
fill(98,245,31);
textSize(15);
text("10cm",1010,490);
text("20cm",1110,490);
text("30cm",1210,490);
text("40cm",1310,490);
text("50cm",1410,490);
textSize(30);
text("" + noObject, 240, 1045);
text("Angle: " + iAngle +" °", 1050, 1045);
text("Distance: ", 1380, 1045);
if(iDistance<50) {
text(" " + iDistance +" cm", 1500, 1045);
textSize(25);
fill(98,245,60);
translate(960+500*cos(radians(30)),500-500*sin(radians(30)));
rotate(-radians(-60));
text("60°",0,0);
resetMatrix();
translate(960+500*cos(radians(60)),500-500*sin(radians(60)));
rotate(-radians(-30));
text("30°",0,0);
resetMatrix();
translate(960+500*cos(radians(90)),990-960*sin(radians(90)));
rotate(radians(0));
text("0°",0,0);
resetMatrix();
translate(960+500*cos(radians(120)),500-500*sin(radians(120)));
rotate(radians(-30));
text("330°",0,0);
resetMatrix();
translate(960+500*cos(radians(150)),500-500*sin(radians(150)));
rotate(radians(-60));
text("300°",0,0);
translate(450-500*cos(radians(30)),750+500*sin(radians(30)));
rotate(-radians(+180));
text("120°",0,0);
resetMatrix();
translate(960+500*cos(radians(60)),500+500*sin(radians(60)));
rotate(-radians(-150));
text("150°",0,0);
resetMatrix();
translate(960-970*cos(radians(90)),500+500*sin(radians(90)));
rotate(radians(-180));
text("180°",0,0);
resetMatrix();
translate(960+500*cos(radians(240)),500-500*sin(radians(240)));
rotate(radians(+210));
text("210°",0,0);
resetMatrix();
translate(960+500*cos(radians(150)),500+500*sin(radians(150)));
rotate(radians(+240));
text("240°",0,0);
resetMatrix();
translate(460,500);
rotate(radians(-90));
text("270°",0,0);
resetMatrix();
translate(1462,500);
rotate(radians(+90));
text("90°",0,0);
popMatrix();
